Results 1 to 8 of 8
Thread: Fuel Pump Problem
    bluebird92's Avatar
    Jan 2012
    Corpus Christi, Tx
    12
    Fuel Pump Problem
    Okay, I was driving along, and I came to a stop sign, and my car just dies. No loud noises just dies. I have it isolated to the fuel pump... I think. It gets voltage up to the connectors in the back seat, but from there to the pump, the voltage drops. I'm thinking I need to replace the wires/ connectors. What do you guys think?
    Nov 2008
    winnipeg manitoba canada
    1,212
    take a rubber mallet and smack the bottom of the tank a few times, report back
    bluebird92's Avatar
    Jan 2012
    Corpus Christi, Tx
    12
    It didn't work...
    Mar 2009
    usa
    1,284
    You've probably done all these steps...but just in case:
    http://www.youtube.com/watch?v=piOzN1tZI_E
    95 Pontiac TransAm Fuel Pump Replacement as a generic analogue to your car (Sorry about the 4th Gen and V8 Part though):
    Part One
    http://www.youtube.com/watch?v=5Rz49rknGPM
    Part Two
    http://www.youtube.com/watch?v=H1l3uEknC-o
    And so THIS extreme effort cries out for a "Trap Door Access" solution to be able to avoid having to do it this way.
    IMPORTANT SAFETY ISSUE!
    Assuming from your name that your vehicle is a 1992 Pontiac Firebird... the tank template locations and dimensions will be much different... so you will have to find a proper thread specific to doing this job unique to your car! DO NOT USE THE 4th Gen F-Body Trunk Panel Dimensions to make any metal cuts!
    Part One
    http://www.youtube.com/watch?v=1_rmWLI4Lbs
    Part Two
    http://www.youtube.com/watch?v=cb0PXiD5RNQ
    bluebird92's Avatar
    Jan 2012
    Corpus Christi, Tx
    12
    Thanks for the videos. The previous owner did that, and I wonder why he did. Now I know, haha.
    I re-checked my wiring, and I got complete resistance across power and ground wire, and I can't find the inline fuse. Where is that located?
    Mar 2009
    usa
    1,284
    I don't know enough about that F-Body generation to say where the fuse might be located. May I suggest a visit to eBay and using this link, you will find your Official GM 1992 Pontiac Firebird F-Body Carline Series Shop Manual at very reasonable prices? That is the only real reference to rely upon for searching around your chassis and finding how things are hidden and arranged, short of having an ALLDATA account:
    http://www.ebay.com/sch/i.html?_from...All-Categories
    there is no fuse between the water tight fitting and the tank side. The only fuel pump fuse is under the dash.
    can you hear the pump run when you click the key on?
    If you have the access panel cut, changing out the pump shouldn't be too bad.
    bluebird92's Avatar
    Jan 2012
    Corpus Christi, Tx
    12
    After much hair pulling I found what I was looking for. Hidden away between the inner passenger fender and the coolant reservoir was the fuse. I replaced it and the car started right back up again.
    Thank you for y'alls advice. It was much appreciated.
