DOHC Performance Build
I dropped my spare motor off at a local machine shop this afternoon. The forged 8.5:1 pistons and rods I bought 7 years ago will finally be going in. I also ordered ARP studs for the crank from WOT Tech. I was looking for head studs, but all I could find was one mention of ARP head studs and another of Raceware head studs. I'll have to follow up on those to see what I can find. I also need to follow up on the copper Flatout head gaskets or Gaskets to Go MLS head gaskets. I'll post pictures and more info as I have it.
Tim
325 whp 350 lb-ft
01-31-2012 07:37 PM
I'm not sure what WOT has for the 3.4 DOHC engine, but have you checked out Cometic head gaskets? As for head studs if you can't find any let me know. I can get custom head studs made.
It looks like ours are the same as the Northstar and they use VW 204-4204 ARP head studs. Two sets on Jegs is $258 shipped.
Next up on the list is seeing if I can find MLS head gaskets that don't take months to make/order.
Tim
325 whp 350 lb-ft
timg
Tim
Let us know if you find anything. And what ARP main bearing studs fit an LQ1? I have some ARP rod bolts, but I thought nothing fit the mains right.
Jesse M.
1987 Monte Carlo SS Aerocoupe
One of the Fiero guys used MLS gaskets from Gaskets to go. They're overseas. The gaskets looked great, but I'll probably only go that way if I have problems.
I talked with my engine builder about the Flatout RCC copper head gaskets and he advised using stock head gaskets instead. It sounded like copper just isn't meant for the street.
Here is the main stud kit from WOT Tech:
http://wot-tech.com/shop/gm-60v6/mai...t/prod_91.html
Tim
325 whp 350 lb-ft
Nice to hear she is starting to go together. Is it a '96-7 LQ1 or what year motor?
S
It's a 97. I bought it with the complete engine harness and PCM. I also have a 96 harness in case I want to keep my 4T60E for a while.
Tim
325 whp 350 lb-ft
Do a 284 swap I would never go back to the auto I absolutely love the 5 speed. If you need help with the tuning for the 5 speed I can help you there.
Dave96z34
I've considered it a few times. You've been tuning your factory 96 computer for the 284?
Tim
325 whp 350 lb-ft
I did it on my 97 set up but 96 will actually be alot easier to do.
