Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: My 3100 build :)
    My 3100 build :)
    I'm currently rebuilding my 3100 in my 96 GP and putting some new performance parts into it and replacing the gaskets.
    I am going to swap over to a 3400 topend gasket matched porting, Pistons, and Rod bearings. Deleted the cat right before the car broke.
    Anyway I think I remember reading that if ya swap over to a different piston that came in an older a 3.1v6 (RWD I think?)that it will raise compression. Also remember reading that there was exhaust manifolds that come on different 60*v6 that flowed much better then stock. Any one have more info on these?
    The tear down.
    Old Rear head
    Old Front head
    Thanks,
    Andrew B.
    2001 Grand Prix Topswap GT-(12.71@107.92mph)
    1996 Grand Prix SE-(17.32@80.23mph) Turbo Project
    1990 Turbo Grand Prix-project restore
    Nov 2008
    winnipeg manitoba canada
    1,212
    your answer should lie in the CR calculator on this site for what compression ratio you will yield, and manifolds from a 3500 flow the best
    pistons for a 3.1 Camaro (gen 1) will yield either 11.4:1 with the .040 headgaskets, or 10.72:1 with the 3100's .060 headgaskets.
    Save your old 3100 pistons, someone who is building a N/A Gen 2 engine might want them. 9.8:1 with .060 gaskets, that's a good jump from 8.9:1
    Jul 2011
    Western PA
    487
    Quote Originally Posted by bob442 View Post
    Remember, on a 3100 you can use 3400 heads, but not 3500 heads. On a 3400 block, you can use 3500 heads.
    I don't know if 3500 intake mani's will fit 3400 heads? Something to check into. Unless you were referring the exhuast mani for the 3500.
    If you got the money, consult with Ben and he'll know what the best top end will be.
    edit: It almost looks like cyl 1 & 3 were getting steamed. And that would be the rear passanger side. I suppose the coolant leak may have been around there.
    How are your cylinder walls? Probably need a good honing when you swap those pistons.
    And might I suggest, since your down there soon, put in a crank scraper as well. Helps reduce parasitic drag on the crank.
    So these are the pistons I am looking for correct
    http://shop.advanceautoparts.com/web...RPENGPAMS_____
    What car should the 3500 exhaust manifolds be off?
    I have a nice 3400 top end if you need one?60xxx miles and everything you'll need heads intakes rockers.
    Im selling it cheap too=) make offers?
    You can use the 3500 upper on a 3100/3400 large port lower or vice verse, but the lower intakes are not interchangeable between the heads.
    Engine is out
    Cool looks good for it's age=) Good luck with the build.Car is in nice shape too.Don't see to many of them anymore.
    Got my 1st new performance parts 3400 Top end. Going to do some home porting and paint it all.
