Results 1 to 10 of 11
Thread: 4T60 Problem?
    4T60 Problem?
    Hi - first timer here.
    1991 Buick Riviera with 120K miles
    Problem: With the engine cold and driving off in the mornings, the car simply won't accelerate worth a darn when I give it gas. It doesn't stumble or jerk or rev high (miss a gear or slip), it will just barely go. It also makes a distinctive whine noise while the issue is happening.
    Once the car reaches full operating temperature the car accelerates and cruises just fine. No check engine light, trans filter/fluid changed 20k miles ago, fuel filter changed - spark plugs look good. Trans fluid color looks good and is full.
    I am thinking that this a transmission issue vs. an engine issue...but of course I am no pro. Just looking for some advice
    thanks Rob
    Nov 2008
    winnipeg manitoba canada
    1,212
    Wow this could be a whole lot of things, does the whine noise happen when idle or in park? Do you have first gear when you have these issues? It could be in limp mode, I had a exact problem with a friends car, it lost its power to the trans because a pin was bent down at the connector to the trans. You will need a mirror to see this, and if it is bent, you need to be extremely, And I mean extremely carefully when bending the pin back if it's the issue, cause if you break that pin your SOL
    Sent from my iPhone using my iPhone at work cuz I have nothing to do
    Quote Originally Posted by bob442 View Post
    Yes- whine happens in at idle and in Park...Are you asking me if I can shift all the way down to first gear? not real sure about that question
    Do you know where that connector is located?
    thanks!
    Nov 2008
    1,212
    Simply do you have first gear, as in does it start in first gear when you shift into drive and you have this problem. If you or someone hasn't touched or messed with the trans lately the the issue I discribed most likely isn't the problem. Does this problem go away when the trans is warm?
    Yes it will go in first gear but it won't move quickly at all. Problem does go away when its warmed up.
    Nov 2008
    1,212
    how do you know the "trans" is in first gear, lets clear this up and go onto the next step i dont think you should be able to go over 40kph in first
    Yes- pretty sure it is in first gear when I start off...It revs a good bit and then "slowly" changes gears to second..
    Nov 2008
    1,212
    it could be having 2nd gear starts or 3rd
    Nov 2008
    1,212
    RPM vs Speed to confirm its in first gear thats all i can shoot at ya
