Results 1 to 2 of 2
Thread: Adjustable coilovers on 88-94 cav?
    I have done some searching and came up empty. I need some help finding front and rear coilovers for my car . I would like to do more then lowering springs and kybs. Also has anyone put 95 and up cav coilovers on an older cav?
    Try ground control. You can use a spring bucket and weight jacker on the rear. Another option is to have some rear springs made to get a good rate and adjust the right weight and corner weights with the spring isolators and front coil overs. The 95 up cars have no steering arm on the strut and a different upper mount. You may be able to work around those issues.
