bob442
You could make your own using the old plug boots and tips, open them up and re-crimp them. I'm assuming your needing them for a 3.4dohc? You can also go to a speed shop and they will have plug wire on a 300 ft roll
Sent from my iPhone using my iPhone at work cuz I have nothing to do
I mentioned the 3.4L wires for those that own one and because they are listed at about half price. I don't know that Magnacor offers cut to fit and I'd rather have a ready to use out of the box set that will work for the 3900 which is the same for the other 3X00 motors.
01-26-2012 10:11 AM
6 > 1
cut to fit sets are perfect for this, it's very easy.. all you need is a can of silicone spray, good wire strippers and a set of crimpers that will do plug wires. The Greenlee 1927's work great, Craftsman also has the exact same ones with red handles for a little cheaper.
I've made my own for a long time, never had an issue and with a V8 set you get extra parts in case you mess up.
Superdave
I don't have a problem with the additional effort in a cut to fit wire, what I'm looking for here is magnacor or equivalent performance and unless they offer them in cut to fit that's not an option, that's why I'm looking for a V8 application that will serve the same purpose since like the small block chevy they'll be easy to find and likely better priced.
Measure how long you need them and tell them the motor, and they will custom make a set for you. That or you can buy their wire in 100 foot lengths, and the ends.
SappySE107
Thanks all, I'll do that.
