3.5sfi inake on 3,4?
Hi! some one suggest to me to put 3.5 compete intake on my 3.4..
I search info on wich T i sould put in. and i think is the lx5 oldsmoble too.
At the begining i lpan to put the 65MM TB. and CAI. with the intake I'll reach more HP and torque?.
Nd its an hard jo to do? smeone can explain me how to swap the intake?. guess is not bolt-on...
01-10-2012 07:46 PM
What vehicle do you have? There are a few variations of the 3.4, of you have a 3400sfi how ever, the intake is all more less a bolt on, the throttle body you will need a TB adaptor and make a custom cable bracket, and possibly change the TB lever with your stock one. Intake requires and fpr bracket as well
I have a 2000 3.4 SFI.
I need :
- lower intake
-upper intake
- TB adaptor
- Tb from oldsmobile...
And other think look like.. what?
I need to change the head of the motor?
I have a Chevrolet Cavalier.
yep... that guy...
Christos05
only if you intend to do the 3500 upper and lower intake manifolds, if you do just the upper, I think it's damn near a bolt on and go thing.
Fiero Owner's group!
Check it out!
the guy who wnat to sell me upper and lower intake. telle me thaht I only need de 3.5 intake gasket. and its bolt on. it's real???
yep... that guy...
no, the lower is not a bolt on without the heads.
Check it out!
Christos05
Not quite. I think you have to use 3500 heads in order to use the 3500 LIM/UIM on a 3400 block. There are also many differences between the 3400 & 3500 UIM including MAP sensor, coil bracket, vacuum ports, and TB mount design. All can be addressed but it's not a straight bolt on and go swap by any means. There's lots of info in these forums that will answer most of your questions and I'd do some research before you start buying parts.
If i only chande the upper. I only need gasket between the 3.4 lower and 3.5 upper. TB adaptor( for de 65mm from Oldmobile) that it's?
yep... that guy...
Christos05
sounds right to me.
Check it out!
