Results 1 to 4 of 4
Thread: 3500 fuel rail issue
    I purchased a 3500 from a 2005 G6 for my RWD project. I've taken the top end apart to rotate the plenums. However when I cleaned the fuel rail I noticed an issue. When I blow air through the fuel line entrance, air only comes out of the injector bosses on one side of the rail? The small can as I understand it is just a splitter but apears to have a restriction that doesn't allow very much air to go to the rail that it's attached to. The rail looks brand new. No rust or anything.
    Any thoughts?
    thanks
    Jan 2007
    Ft Lauderdale, FL
    4,270
    The 3500 fuel rail is return-less. If you are using a conventional fuel rail, you need to source one from a 3400/3100.
    Gordon, Mine did the exact same thing, so I assume it is normal.
    Roy
