Multiport coverted to carb!
I have converted a couple mutliport engines to carb and hei distributor, i want to put pics up, could someone help me with that????
12-20-2011 11:28 AM
Here ya go
What you think??
First off, welcome to the site.
Secondly, looks very interesting! Any reason why you put the carb up on such a raised box instead of closer the the plenum top? Seems like you'd have much better clearances. Will that even clear any kind of hood?
Brad via Tapatalk
RWD FTW!!!
I spy two of these upper plenums. A 2.8 and a 3.1 plenum
Mars
Haha ^ Wrong Wheel Drive.
No 60šV6 at the moment
just when you thought you had seen everything
The box is for throttle clearance, i doubt it would clear the hood with carb flat on the plenum, these setups are for derby cars,(shoulda mentioned that). Although i want to take the next one to the drag strip before i gets smashed cuz these buggers scream!
I also got a pipe dream of using a w body(lumina) subframe with one these setups on a ratrod someday. Probably use a 3100sfi for that though.
I thought they might be for an open class dirt track car or run what you bring class roundy round beater
6 > 1
lol, this thread made my day.
Why a little 2bbl q-jet? Put a 4bbl 750 q-jet on it and see if it holds together.
EveryDay: 2001 Alero 2.4 5-speed
Hualer, Mpg? ROFL: 1984 Buick Electra Estate Wagon Fresh 3oh7 268h camming. OEM 84 2004r
