12-15-2011 01:11 PM
Welcome to the site!
Its hard to tell... But looking at your pictures, you have it pooling up on both sides of the engine? Have you looked at your oil yet? Typically, when the LIM gaskets go back, they leak internally, although I have seem some that leak externally like you are showing. But to be on both sides of the engine, either you are going to be really lucky if it didn't leak into the engine, or you are going to be in significant danger of having internal issues soon. I can't think of anything else besides the LIM that would cause coolant to pool up on both sides of the engine.
Can you see any traces of coolant having run down the side of the heads around where it is pooling? That middle picture looks like there might be some... I would definitely look inside the oil fill cap ASAP, and if it looks like a milkshake, stop driving the car until you can get it fixed. By that point, though, it may already be too late.
Ok so its mostly on under the throttle body with little spots on the otherside next to power steering pump. My oil is fine as i check everytime i have to drive the car (try not to drive it) as there is not oil and coolant mixing(ive seen pictures of some coolant and oil mixing and it looks nasty). and it weird cuz it doesnt leak fast my low coolant light only has came on twice(recently) over two years. Im going to try and soak up as much as the coolant i can and run the car for while and try to see if any is coming from the heads
Accelerating uphill in OD
Have someone pressure check the cooling system. By pressurizing the system without the engine running you can sometimes hear where it's leaking externally.
well if it wasnt the LIMG, then you would 110% identify the problem when you tear it apart to do them anyways. but it looks like thats the problem as you took pictures from both sides of the intake
Azrael
we already pressure tested it at "15 psi"
bob442
i already got started tearing it down but i am stuck on one nut (silver nut ) that hold black pipe into lim next to thermostat???? and i can't get it with any wrench, socket, or anything so hopefully one of you guys can help me out
Probably need a crows foot wrench to loosen that.
Brad via Tapatalk
bszopi
Brad via Tapatalk
i was getting extremely frusterated so i walked away from if till step dad got home and he acutally got it lose enough to slide the pipe back literally 5 minutes after i posted the question. so now all i gotta do is wait for tomorrow to get the gasket and but i think im going to be order the lisle push rod remover (lis48500) so i dont have to mess with the rockers.
The rollers rockers are easy, not sure its worth the $$, IMO. All you do is loosen them up enough to remove the pushrods (make sure you keep them in order when you remove them!). When you are putting it back together, just tighten the rockers to spec. Its not like you have to adjust them or anything...
A 20$ tool is worth it to not have rocker threads strip out after the engines all together, don't forget to do your t stat, and change your oil/flush incase of contamination
