Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: TDC Sense
    TCE makes the trigger that WOT sells.
    Sent from my Galaxy Prevail using Tapatalk.
  3. #12
    Don't know if it was mentioned above, but you cant use the LX9 balancer with the external crank trigger. I believe I used a 3400 balancer.
    1994 Corvette
    LT1/ZF6
    2006 Dodge Dakota 4x4
    3.7/42RLE
  4. #13
    you can use the external trigger on the LX9 balancer, fits perfectly fine. I can get pictures if you want.
    Fiero Owner's group!
    Check it out!
  5. #14
    OK, I assume you mean the sensor and balancer that came with the LX9? There are no notches/teeth on the back to trigger the sensor. Also the LX9 sensor is a 3 wire sensor; the ODB1 coil pack/ICM uses a 2 wire sensor. My other option is to get a crank pulley and sensor from a 3100 or 3400. Comments?
  6. #15
    Nov 2008
    winnipeg manitoba canada
    1,212
    as long as the LX9 has the pre-visions for the blue 24x sensor that mounts towards the inside of the 3400/3100 balancer, if not you need a timing cover aswell, is this a RWD or FWD setup?
  7. #16
    It is a RWD. I plan on using the front cover from my 3.4 ('94 Camaro/GMPPC HT3400). I am going to be using ODB1 with a harness and ECM from a '94 Cavalier.
  8. #17
    Nov 2008
    1,212
    Yeah then your set.
  9. #18
    It is also keyed just like the crank so you can't put it on the wrong way.
