FFP Dog-Bone replacemt bushing part number got it!
Sticky!
After much Searching I found a suitable replacement bushing!
Energy suspension Part number 9.9107G about 10$ comes with all 4.
Re use your old center shafts. looks good and is a extremely tight fit like a virgin!
11-16-2011 03:09 PM
Good to know. Thanks.
Tim
325 whp 350 lb-ft
I think I had a set made from delrin at one time... never installed them since I'm using a 60* inclusive one on the 96, IIRC the FFP one is still on the 95 out in the driveway.
Sweet, polyurethane I am assuming. I swear mine has just rubber bushings in it.
-Matt
I wonder if these bushings are the same ones RSM used in their poly dog bones. Reason being, RSM just stuck poly bushings in stock dog bones meaning anyone could tear the rubber out of their stock bones and put these poly inserts in and have a poly dog bone cheap....
It depends on the application though, I know those wont fit mine since my dog bone is thinner on one side than the J-body guys and W-body ones.
pocket-rocket
I don't think it is the stock rubber is alot bigger inside the the ffp ones.
