95 3.4 Camaro interference motor?
Hi everybody,
This is my first post. I broke the timing chain in my car the other day and was wondering if this motor is a bender (interference motor)? I searched and it seems as if the aluminum headed motors are but i didnt see anything about iron headed ones?
11-14-2011 07:04 AM
6 > 1
Yes, it is. People have gotten lucky though.
welcome to 60v6!
Hey,
Thanks for your reply. I guess im one of the lucky ones then. It did break at a relatively low rpm though. Got it all back together and all seems well.
I just noticed youre from the qc. I lived in Geneseo my whole life til about 2 years ago when i moved out here to CO.
Making it work
Superdave
welcome to 60v6!
Yes, welcome!
Are you sure iron heads are interference, Dave?
6 > 1
Should be, If you have one laying around measure .47" ( lift + HG thickness) from the lowest point of either valve. If that ends up below the surface of the head then there is a chance that the piston will kiss it. All i have are aluminum heads, and they are for sure.
Cool, i've been through Geneseo a few times over the years. I'm in Davenport, kinda by the east village.
One guy thinks it is and one doesnt. Anyone know for sure?
Making it work
With stock parts, it's definitely NOT and interference motor.
http://www.thirdgen.org/techboard/v6...ce-engine.html
The 2.8 had flat top pistons, the 3.4 has an 8cc dish in them. If the valves don't hit on a 2.8, then there is more clearance for the 3.4
6 > 1
I guess there is one advantage to having iron heads.. lol
thanks for the response guys. i guess i wasnt as lucky as first thought although nice to know if it does it again
