stock flow numbers for both style of heads
so i have benn trolling around the forum recently trying to get flow numbers for 91-95 and 96-97 dohc heads. and i am having differing results. i dont mean to say that the numbers that are on here are wrong. its just that i think we should have a base done because it seems that everyone always asks what the flow differences are. i have sourced a 94 head and a 97 head and a flow bench from a buddy of mine that works in a machine shop. some time in the next week i will have flow numbers to give to the community off the same bench on the same day.
10-31-2011 08:44 PM
Here's s spreadsheet I made years ago with numbers I got off this forum. I would love to see how what you find compares as I had different numbers from different sources with different equipment. Thanks for doing this!
Tim
LQ1 specs.xls
325 whp 350 lb-ft
thanks for the spreadsheet i am kinda excited to see how close or far away our numbers were from one i get. i am using the lower manifold for the year specific head and about 3" of exhaust manifold runner, also the tech does have a bore that is 3.63" in diameter so we will be using that. so numbers should be very close to actual. since im doing this for the community i will be doing flow rates in .050" increments all the way to .500" lift on both intake and exhaust.
Those aren't my numbers for the 91-95 heads. Don't use the lower, use some clay to make a rounded entrance to reduce turbulence. If you are going to use the intake, do the lower and upper with the throttle body (no plate though) and all vac ports sealed. That will give you the best numbers. Its worth more knowing that than just the head flow.
sappy what are ur numbers for the heads? if u dont mind me asking. i figured using the lower would be ok because it would kill some of the turbulence and it looks like most people have either the cut runner intake or are doing some other sort of intake. so i thought that it would give them a base for what their intake had to flow to match. if i use the whole intake and someone wants itbs then they wont know what kind of numbers their intake has to flow in order to not be a restriction for the heads. but everyone still uses the lower manifold. im not trying to start an argument but not knowing a whole alot about flowbenching stuff that is what i thought would be a starting point.
