Page 1 of 16 12311 ... LastLast
Results 1 to 10 of 157
Thread: Roberts 89 GT/U build 3400/3500 WOT-Parts
    Dec 2005
    Plainfield CT
    3,192
    I figured I would bring this over here since its comprised of WOT-Tech parts.
    List of parts to be installed
    SBC 350 Cam Bearings
    LS6 lifter springs
    Custom Cam, 206/206 duration at .050 533/533 lift.
    Smith Brothers Pushrods
    3500 Ported WOT Street and strip heads
    WOT Street and Strip 3500 Lower
    ARP Head Studs
    TCE Double Roller timing chain
    And do a full road tune.
    Well, Robert dropped off his car Saturday (10-15-11) and I moved the cars around today and got all his parts out to see what I have or may need.
    Pinky's gonna have a chat with the GT and teach her how to idle with a bit of lope...
    I need to put all of this
    Into here... And make it look good...
    Maybe if I just leave it like this overnight all of those parts will just jump in the bay...
    Dec 2005
    Plainfield CT
    3,192
    Tuesday 10-18-11
    Well I dropped the 5-speed with a trans jack first then removed the motor, similar to doing the auto and if you angle the engine down the trans clears the frame rail very easily to disengage the trans from the clutch.
    Few concerns about the current install though... For instance, these are the fuel lines...
    WAY too close to the exhaust for my comfort... I am going to see if I can get my hands on a new set of 3100 lines from a 94+ car to fix this right.
    Also the heater core lines are very badly routed and pretty much LAY right on the header cross over pipe... I'm going to also find 94+ beretta parts, I have the front rail pipe that doesn't have the TB heater lines so I'll use that and try to find a hose that will route around the headers.
    Just some other pics.
    I need to re-wrap the front header
    Pulled the crank so I could get it to work to have it modified since that guy is on vacation next week.
    Crank out.
    Dec 2005
    Plainfield CT
    3,192
    10-20-11
    Crank modified for the TCE setup.
    Slight issue on the timing set though, the side that faces the block has the timing marks, not the side facing out and I can't just reposition the marks to the other side since once flipped 180 the timing mark is on the opposite side of the key way... I sent TCE a PM asking him about this issue.
    My crank gear doesn't look like the one below.
    Marc and Ben have been working with me to replace this gear, It somehow got mixed up with one of Bens RWD DR sets so he is going to send out the right crank gear. Thanks Ben!
    Dec 2005
    Plainfield CT
    3,192
    Last nights updates
    Cleaned up the garage and tore it all apart.
    Parts Pile 1
    Cylinders look great and have no bad markings on them.
    Robert one of the stock cam bearings was staring to fall apart.
    Parts Pile #2
    Empty Bay
    The rigged heater core lines I'm doing away with
    And a nicely built set of Milzy headers... I honestly can NOT argue the quality of these... For Roberts sake I just wish the coating was done better.
    trewyn15's Avatar
    Oct 2010
    Janesville, WI
    160
    looks like a good build, is that surface rust on the headers?
    2004 Monte Carlo LS
    Build Thread
    Youtube Channel
    ^Add and Sub & I'll Return The Favor^
    Yeah it has a few small spots of rust on the headers.Next winter i'll pull them and get them re-done unless jon knows someone?Nice beretta though
    Mr. Common Sense mfuller's Avatar
    Nov 2003
    Loves Park, IL USA
    313
    Quote Originally Posted by robert 1980 View Post
    Nice build. My WOT headers will go to Swain Tech for coating (someday).......I'd recommend them if you are thinking about getting yours re-done.
    trewyn15's Avatar
    Oct 2010
    Janesville, WI
    160
    didn't he just get them? i thought the coated was a big part of their pricing
    2004 Monte Carlo LS
    Build Thread
    Youtube Channel
    Quote Originally Posted by trewyn15 View Post
    They have been on the car almost two years.Milzy told me the shop he uses closed so he had the guy that worked for the owner coat them.The back one is getting shitty i'll see what i can do but i don't think there is enough time.
    Dec 2005
    Plainfield CT
    3,192
    Roberts going to call a shop near him to see what turn around time is, I know that is typically 2-3 weeks for some places and by then he'll have to find a storage unit up here since there might be snow on the ground... so we are trying to get it done asap...
    I should have my hone tonight so after some house clean up for guests this weekend I'll probably head out and hone the block then clean the block really good and get the paint on it...
    It's actually supposed to snow this evening Rob... LOL Mixed with rain though.
