they are heavy(cast block) and a FWD trans wont like it too much. the only hard part about this swap would be getting the gauges to work properly, i dont know if they use the same signal or not, hopefully a fiero darksider with chime in for that answer.
01-14-2012 09:23 PM
ericjon262
Welcome to the dark side!
Nope. In relation to a stock Fiero, putting iron heads on an aluminum head motor is the darkside. Swapping in some aluminum while at the same time loosing some weight and gaining more power and a roller cam is all "light" as in eureka!
Joseph Upson
Yup, lighter+more power just makes more sense.. There will definately be a turbo in the future too! I used to have a turbo colt and that thing could haull a$$! I'm kinda sorry I sold it but I needed to to focus on the fiero..
Here's the link the my colt build: http://www.cardomain.com/ride/216031...itsubishi-colt
Well, the guy got back to me and said I could have a 99 or 03 engine.. Which one would make more sense to get??
6 > 1
That's what I figured
4 years newer and the same cost! I just didn't know if there was any significant differences in the years.. I checked the family tree on this site and it seems like they are pretty much the same..
better flowing upper and lower intake IIRC, the 00 stamp on the lower intake is what would be more desirable, i recall ben saying something labout that to me. i could be wrong
Use 3400 DOHC pistons, flat top with valve reliefs. That's what I did.
'86 S10 Blazer 4WD, '87 2.8 with 3.1 crank and pistons, A.R.I. "Stage 2 Cam", Iron Heads with stiffer springs, Holley TBI, Manifold bored to fit the TBI Base(4.3 size), Fiero Covers, MSD Coil, DynoMax Muffler and 2.5 Tailpipe, no cat, Auburn Limited Slip, 3.73 final Drive. 700R. '85 Fiero GT 3.4 Hybrid, relieved top intake and exhaust, 57mm TB, Auto. 3.06 final drive.
yep... that guy...
Ray Hamilton
or just keep the better flowing top-end, power, and fuel econ of the stock 3400...
Fiero Owner's group!
Check it out!
I was thinking about doing that, but I figured it would be harder to find DOHC pistons than doing a bit of extra wiring.. Plus I don't have the time to do any internal work right now. It's good to know tho just in case I decide to go for the stock look later!
yep... that guy...
newfiefiero
My vote would be to make the 3400 look stock.
Check it out!
