yep... that guy...
262's 85 Fiero SE LX9 F23 swap thread lots of pics
I posted my build thread on pennocks, and I'm posting it here too, I'll keep it updated
I finally called it quits trying to fix my 1985 Fiero SE's 2.8, the car just wouldn't run, so I made the choice to pull the old iron headed POS and put something new in, 2 something to be precise!
Here's what I started with...
and here's the new stuff!
My F23!
My LX9
I decided on the LX9 3500 for several reasons, it's compact, it's lighter than the stock 2.8, makes good power per liter, and shares some similarities to the 2.8 dimensionaly they also, sound cool!
I cut the bottom of the trunk out to make room for an exhaust, and possibly, turbos!
This is my $15 alternator, went for the bracket, popped the hood, and there it is, a brand new delphi!
Steel crank FTW!
Clutch, Crank trigger, and TB adapter!
Crank trigger semi installed!
LX5 "shortstar" throttle body.
Uh oh!
Here we go!
Obligatory "me in the engine bay" pic
Engine and trans hovering over the cradle.
BEST CREWCHIEF EVER
Remote oil filter adapter and custom plumbing.
Right now, I'm neck deep in wiring, and halfway done with the engine and transmission mounts.
thats my front trans mount, unfinished, I've cut the tab and ground it smoother.
I'm still working on my front and rear engine mount, and my rear trans mount, I'll keep the thread updated, and post lots of pics along the way(like I said, dailup beware!).
Fiero Owner's group!
Check it out!
10-03-2011 11:57 PM
Hey this thread looks familiar
'87 Fiero SE
Very cool!
BTW, which clutch are you using?
yep... that guy...
Blacktree
Very cool!
It's a Centerforce dual friction, I was going to get a spec, but my local shop couldn't order from spec.
I got some of my poly mounts in today, so hopefully I'll get my engine and trans mounts done soon!
Check it out!
Did you decide on what to replace your upper dog bone with?
yep... that guy...
Kaiju Senso
I think I'm going to make a dogbone mount that goes under the coilpack and above the exhaust.
Check it out!
yep... that guy...
I got my balancer!
Check it out!
yep... that guy...
unfortunately, I don't have much to report, other than that I've painted the engine cradle, finished the bulk of the wiring, and spent lots of $$$ on parts...
Parts list as of now...
Big LS1 Camaro Brakes
New front swaybar current front will be moved to the rear.
Rodney Dickman aluminum cradle bushings
KYB struts that I'm converting to coil-over
a big mess of pipe Stahl Headers
Collectors, also from Stahl
new Rodney Dickman front motor mount
Thelin F23 rear trans mount.
Painted and polished the intake!
Hello, think i got enought to make two sets!
Parts to be ordered soon (hopefully)
SS brake lines
Vbands for the exhaust
flex couplers for the exhaust
Poly bushing/mount kit
o2 sensor bungs
HT motorsports front suspension kit (hopefully)
http://www.westshorefabricators.com/...itCarSport.htm
Check it out!
wow, those bends are HUGE! fun looking project, is this engine running on OBDI or II?
yep... that guy...
bob442
The tubing is only 1 5/8", I haven't made up my mind on obd1 or obd2 yet, right now, I'm wiring it up so I could run either. obd1, the inital costs are higher, but I'd be able to tune it, obd 2, would be cheaper initially, but cost more long term because I don't have the stuff to tune it.
Check it out!
