yep... that guy...
obd1 Vs obd2
I'm in the middle of wiring in my 3500 swap, and I'm trying to decide whether to go obd1 or obd2? if I go obd1, I'd be running the EBL flash P4 seen here EBL flash P4
I'm not sure which ECM I'd run if I went OBD2. I don't' know enough about it to make a decision. i do know I would have to get HP tuners to tune it, and it would probably be easier to find a shop to do a dyno tune on it.
Any thoughts?
Fiero Owner's group!
Check it out!
09-27-2011 11:34 PM
OBDII is a newer technology and should theoretically give you more/better control, but you need to make sure your starting with an ECM and bin that is decoded quite a bit, thats where OBDI has a bit of an advantage... the main code used for almost all the v6 swaps is fully decoded, or at least I found that out earlier this week... OBDII hasn't been beaten up as much yet and bins are still only 75% or less decoded so that leaves some controls out of your reach.
I guess it depends on which car your starting with and how much work each control system will require.
I'm going to throw in with the 7730 too. Yes OBDII can do additional tricks but I like the fact that OBDI is less cluttered. It's also cheaper. I haven't put in too much research but the OBDII software I've seen costs hundreds of dollars and TunerPro is $30. I also used 90% of my original harness so there was less layout.
~sam
6 > 1
Sometimes more is not better, OBD1 has proven itself to handle anything thrown at it. The weaknesses of $A1 have been addressed by Robert Saar in his na$t1 development. You have huge VE and spark tables and all the things you need for a daily driven car. You also have the advantage of an emulator so you can tune on the fly, with OBD2 you have to stop and re-upload the file every time you make a change.
My vote, 1227730 ECM with nA$t1, a Ostrich Emulator and a ALDL converter.
For what it's worth, there are hundreds of 3x00 swapped jbodies running 7730 ECM's and tuned chips.
yep... that guy...
well, as of right now, I do know this, if I were to go obd1, I would almost definitely be running one of the dynamic EFI boards in a 7730. or their EBL SFI-6 unit if it's available by the time my car is ready for it...
Check it out!
