Name that ECM
So... Bought a WOT-Tech chip from Ben and am having something of a problem with the install. Laugh, I know. The ECM is located under the coolant tank in the front right quarter of the engine, right? Located it and took it out. Unfortunately, I'm seeing something different than I would have expected. I have a '93 3.1L GP.
The pictures below are what I see.
It definitely doesn't look like the ECM from this thread.
http://www.w-body.com/showthread.php...t=chip+install
Am I going crazy here?
09-26-2011 11:29 PM
First off, welcome to the site!
Secondly, that's an OBD-1.5 ECM, so unfortunately the chip won't work.
And to make things worse, those PCMs currently aren't really tunable (there is someone on here working on it though). Good news, with that PCM, it means you have a 3100 and not just a 3.1L.
Ok what the f. I thought that the 1.5 OBD was only 94-96. *growl* Guess I'll be looking at the vin number a little more closely to see what style motor it actually is. At the very least the air intake is still the old 3.1 style so I still have a restrictive intake.
I really wish I had been around when my girlfriend had the motor swapped in the car, but that was before I knew her. I guess on the bright side the tiny DIC I grabbed from a '95 will actually work.
93 was the first year of the 3100 and only select vehicles received it. Oddly, I DIDN'T think the GP was one of these...
Do you have a pic of the engine? Since you say there was a motor swap, I'd be interested in seeing what is inside that thing. Posting the VIN would also be helpful in trying to sort things out.
I didn't think the GP was one of those either; I'll post the VIN on the dash. Where is the engine's VIN?
There's a lot of confusion on what happened with the engine. Engine had *something* done to it after it cracked a head (overheated). It may have been a rebuild, but may also have been a motor swap. Her family is not mechanically inclined to say the least. Now I'm just trying to figure out *why* they would have swapped the engine harness for a damn motor swap.
The air intake is definitely 3.1L though, so if a swap happened they only did the block itself.
The 8th digit in the dash VIN is "T", which means it came with the 3.1L right? Here's a quick pic of the engine bay, where you can see the top of the 3.1L intake.
Did they really wire that thing up for SFI? Correct engine, wrong PCM. That is quite interesting and I am not sure how or why they would use that computer. MPFI was never flash.
I'm going to look at the Vin on the engine, as soon as I can locate it, to verify what style engine block it is. My girlfriend said "they got something close that wasn't exactly right", so I'm hoping that there *is* a 3100 under there to justify the wiring change. I'm sad that they killed it by putting the stock intake back on though. I'll probably change it back to the OBD1 box / 3100 intake (if the engine is a 3100), but damn if I'm happy about spending more to fix their mistake.
At the very least I'm beginning to understand why they wanted so much money from her!
Look on the block for a big letter. IIRC, a 3100 would be "A".
Brad via Tapatalk
Thanks Brad, I'll take a look when I get off work. Where on the block should I be looking for that letter? Radiator side? Accessory side? Throttle body side?
