got a few questions
well I just dont know the answer. I should because it seems basic.. search came with no results.
setting up ms finally, its in the car.
im running ms for fuel and 7730 for spark. do both need the tps signal? I didnt think so but I read something saying its needed for timing.
are these considered odd fire engines or even? im assuming odd..
not getting a tach signal so im trying to make sure all my settings are right. worked just fine with the stim
09-24-2011 07:00 PM
my settings so far, not 100% sure on a few of them but I havnt had too much time to look into the past few weeks. still no rpm reading. not even with the stim now.
if anybody happens to see anything wrong with those off the top of your head please let me know. im still learning the technical side of this lol
Alxsmt
Both will need a TPS signal and the motor is a even fire motor. Where did you get the coil trigger for the MS?
ok thanks, I guess I gotta change my harness a little. what do you mean by where did I get the trigger?
