Results 1 to 9 of 9
Thread: mapsenor?
    Question sensors?
    will the map sensor on my 3500 be compatible with a 7730? it's a 3 wire unit, but about 1/3 of the size of the other obd1 map sensors.
    Thanks-
    Eric.
    The newer style sensors are supposed to work in place of the older ones just fine from what I've read.
    Sent from my SPH-M820-BST using Tapatalk
    Awesome, they're much smaller, so they also look alot better!
    Agreed. I was going to use that style when I do the intake swap on the 92.
    Yep, they work just fine.
    sweet! Now I just need to find a 3 bar off a ZR1...
    Next Question, does anyone make a 5 wire maf suitable for my LX9?
    Quote Originally Posted by ericjon262 View Post
    Not sure why you would need a MAF sensor when you are using the map?
    I'm looking into a modded obd1 ECM that uses maf and map.
