Anyone in MD?
anyone in MD know anything about tuning? about to start tuning on my 3500 swap into my fiero... have DHP tuner.
08-01-2011 03:42 PM
I'd love to see that setup and how things go. Maybe I'll go to OBD2 next time.
~sam
actually Cockeysville, MD (I should update that...)
as soon as i get it running id gladly let ya take a look :P
im over in essex (the wooded part not the ghetto part
Nice,
I love the idea of the 3500 but decided to go for the 3400 to keep the downtime low. Hope you get it tuned soon.
~sam
i cant even get the damn thing to start :/ im really pulling my hair out!
Do you know for sure what's holding you back, air, fuel, or fire?
fuel, i cant get the f'ing injectors to fire... (checked with noid light) was running98 venture pcm, thought "maybe bad pcm" grabed an 01 impala, same issue...
goiing to re-scope out all the sensor readings tonight, and try the 98 ecm again :/
I don't know if it's the same for OBD2, but OBD1 needs extra grounds from the block to ECM to fire the injectors. Did you test to see if you have power at the injector plug with the ignition on? You could also try triggering them manually. Would get you enough fuel in the manifold to see if the rest of it's working. Good luck.
~sam
X2 on the grounds and do you have the right crank sensor ?
was bad pcm... flashed a yard pcm w/ the non-vatts 98 programing, got injecors and all, taped it with a hit of starting fluid... it started for all of 10seconds before it went CLUNK
and locked up
