Help w/ DHP
Tonight I was trying to flash my PCM with a small change and my DHP and will not flash and it also cannot do a PCM read. It tries and just gives an error message about not being able connect, do you have the ignition on, etc. This is strange because it has no problem reading and clearing DTC's and it reads all the sensor data just fine so I'm not real sure what the problem could be. Any help is appreciated. Thanks,
Jesse
Jesse M.
1987 Monte Carlo SS Aerocoupe
07-05-2011 09:00 PM
jman093
Jesse
I would start over and the first thing i would do is perform a Read PCM. If it wont work check the version you're using, the latest I believe is fully unlocked. Have you been tuning all along or are you just starting out?
'96BerettaZ26- Med Adriatic Blue- FINALLY swapped '04 Impala 3400, Comp Cam, Comp 26986 springs, TCE lifter springs, WOTTECH Comp ported U&LIM, TCE 65MM TB, LM 4t60e~~~Looking for 3400 Downpipe
