06-26-2011 08:40 PM
That thing looks massive for that motor lol. Lots of machining I see. I guess if you have the sources and the know-how, the entire build could be all junkyard parts... I'd like to see it run when you are done!
Destruction Worker
I forgot about this, any progress mikeal6031?
I haven't been able to do much with it with workin two jobs and college but I switched vehicles im putting it on because my 3.1 Rs has a serpentine belt which will be easier to work with than the 4 rib and v belt that I have on my 86 base, the onlything I really have to do is drill 8 holes in the adapter plate to mount it to the intake, and then I just have go bolt it up and put a belt on it. But then the tuning aspect will come in, I have 350 v8 injectors which should work well, I have to monitor the afrs. With the wide band to make sure its not goin lean but im sure im goin to hit some bumps in tuning it.... I've learned nothing ever is as easy as it sounds Haha
but ill try to get a runnin video up on you tube when I get it done
Destruction Worker
W00T! I would be very interested in a video when you can get it up and running, very cool.
My posts are moderated
How are you planning on getting the TB to work?
Personally I don't think that is the best idea.
With the parts at hand I guess you are doing okay.
I would have turned the supercharger around 180 degrees, taken the snout from a 98-03 Benz SLK C230 (link) and ran a dummy shaft back to the main belt. This seems like a good bit of fab work, but your TB will be on the proper side and you wont have to mess around with using crush bent exhaust tubing for an intake...
Pic of what I mean
