Results 1 to 6 of 6
Thread: Suspension energy or moog part numbers for rear
    Sep 2009
    Camby, Indiana
    85
    I am doing a suspension overhaul on 92 GTP 3.4l 59K miles because rear calipers were seized anyway. The front is easy, but rear stabilizer bar is giving me issues. I can get a moog K80233, but I can't find any other bushings. Energy makes a 14mm bushing to go on strut, but it is not tall enough. Autozone makes bushings but they are just rubber. I could buy an adco 474 rear stabilizer bar for 165.85 from summit and I think it comes with new poly bushings. Any thoughts?
    1992 Grand Prix SE 3.1l 155k SOLD
    1992 Grand Prix GTP 3.4l 55K
    1991 Grand Prix GTP 3.4l 5 speed 99K SOLD
    1988 Pontiac Fiero GT 2.8 5 speed Turbo 36K Sold
    2011 Mazda 3s 5dr 6 speed
    2008 Grand Prix GXP 5.3l 24K sold
    http://www.energysuspension.com/prod...-Bushings.html
    There'll be something there that will fit your bar size. Just measure it and if nothing is exact just get the next smallest size and squeeze it on there. This is for the end bushing on the strut. I have an addco and even the inside bushings on it are rubber, probably since it uses that weird hangar.
    Jesse M.
    1987 Monte Carlo SS Aerocoupe
    Sep 2009
    Camby, Indiana
    85
    I do see 9.5153r which is a 14mm one which is the same size as my rear bar as it is FE3, but two concerns are that this is only 2 1/4 tall. The stock one is 4 inches tall. I am afraid it will be pulling the bar too close to the strut. Also for the front guys have written up that they had to go 1mm size bigger for the energy greaseables in the front. for the 14mm bushing I can't go to 15mm I would have to jump to 16mm. I could go with a non-greasable one which is 9.5103 and only 14mm. I believe that was the concern on the front that if you got a busing that is the same size as the bar there would be no room for grease. I do not want binding or squeeling from a non-grease even though energy says it is impregnated so no squeel. What are your thoughts about greaseable 14mm or non grease 14 and the fact that the energy bushings would pull the bar closer to the strut by about 1 1/4?? Running polys on the outside on the rear bar and new autozone rubbers for inners and new moog hangers, will that work okay?
    Quote Originally Posted by Cidacious View Post
    The stock one is four inches tall? The ones I remember seeing are right there close to the strut. My brother's 90 GP with a dinky little stock bar has the same bracket as my poly's on the addco bar and it's no 4 inches. All I know is my larger Addco has no problems rubbing on the strut with a short bracket. The only time it touches is when the rear is jacked up completely off the ground and that's only because the bar is bent different than stock.
    Noise isn't much a problem on poly sway bar bushings in my experience, but they do wear out a lot quicker. It would definitely help out to keep them greased. They're not all that expensive, so if you don't mind replacing them every 40 or 50 thousand miles or so there's no problem getting non-greaseables if they fit better. Grease them though before installing.
    Jesse M.
    Sep 2009
    Camby, Indiana
    85
    Yeah, I don't know what I was thinking the stock bracket is 2 inches tall but the energies are just 1 3/4. The energies bar hole is 3/4 up, and the gm/autozone rubber is 1 inch up. It is good to hear about the rub/noise situation should be okay. I only drive the car 3 - 4k a year, so I won't care about short busing life.
    Surrey, BC, Canada
    5,520
    Poly bushings squeak no matter what energy suspension says. Get the greasable ones if at all possible. There is a groove in them bushing that will hold the grease in there. It will never squeak and almost last the life of the car. You do not have to choose an oversize bushing. Measure the bar and get the one that matches.
