OBD1 into 80 Monza
I am in the process of sorting out a 92 Z24 harness to use in my 3500/Monza swap.
I need to know if I need to hook up either of the following in order for the ECM to function properly. Can I just pull the pins or do I need to ground them?
PIN D13 Idle speed power steering pressure switch
PIN F7 Evap emissions purge selenoid
Also what do I have to do about the EGR pins E9, F4, and F5 so as not to throw a code?
Thanks
Roy
05-29-2011 08:00 PM
Destruction Worker
I wish I had something useful to add other than "please post pics".
A 3500 in a Monza is definitely worth seeing.
if you account for them not being there in the tune, you can do whatever you want with those circuits. ideally, i would hook up the power steering switch since it's used to raise the idle speed when the power steering pressure jumps high, but i imagine your steering rack doesn't have the provisions necessary, so not a big deal.
PM me!
6 > 1
You'll have to tune it anyways like Robert said, when you get to that point just turn off the EGR and the CCP.
In for pics
Destruction Worker
Hell yeah!
I wholeheartedly support this build
correct, when grounded that circuit either adds IAC counts as a precaution to keep idle speed stabile, or it actually raises the desired idle speed in the ECM and adds IAC counts anyway.
PM me!
