6 > 1
check all your engine grounds, seen that before.
07-13-2011 01:12 PM
I was having a problem with my alternator not charging very high. I put a 10 guage wire from the battery to the alternator and is better now. I also put a 4 guage for the battery to the ICM mounts. It still does it. I will try another body ground and see if that helps.
Brent
6 > 1
the ICM doesn't ground through the mounts, only the ground wire from the 2 pin power plug.
