Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 91
Thread: 3400/325 e30...project GMW!
  1. #51
    Quote Originally Posted by hefftone View Post
    The 2.2 came directly from fwd, so the starer is on the dirver side (in rwd config) and uses a different bellhousing than the 2.8. I had a 2.8 S-10 and it did not have dual starter pockets.
    The 2200 in the 01-02 Cavalier had a GM Metric bell housing like the 60* and 3800s. Starter is on the driver side of course.
  3. #52
    bellhousing is from a 95 2.2l s10, which has the starter hole on the correct side. its a modified unit from british sports car conversions.
    [SIGPIC]
    12.268@117... 11's to come!
  4. #53
    been busy lately with little things. drivetrain pulled out and on stands. degreased transmission and wire wheeled the entire casing, except the shifter which i have a new one for. i decided while the engine was out to clean/shave brackets in the engine bay. used undercoating to spray "frame" portion down and the front of the trans tunnel. painted the bay semi-flat black rattle can 4 coats. turned out decent for the theme of the car which ill give away when i get to it. i also decided to start powder coating things myself instead of a buddy, so i hit up craigslist...bam $50 working oven, and $60 for my buddies old hot spot eastwood powder coater. i used matte black on the engine mounts and transmission mount, turned out great. Another swap going on as well..i picked up a steering rack for a 95 m3 from a local european salvage yard. turns out the rack is zf remanufactured with new tie rod ends for only $80! more good things to come!
    [SIGPIC]
  5. #54
    Nov 2008
    winnipeg manitoba canada
    1,212
    WINNING!!!
  6. #55
    Jan 2007
    Ft Lauderdale, FL
    4,270
    Nice score on the rack. They are $80 at the local yard but they never have m3's lol.
  7. #56
    i figured i might as well swap it while i got the engine out.
    [SIGPIC]
  8. #57
    That looks sweet! I can't wait to see it!
  9. #58
    some new things done. engine parts are cleaned up and powdercoated. built the alternator bracket, used a turn buckle for the tensioner. decided to delete powersteering all together. picked up some awesome powder for powder coating. now that the engine is all together (almost) its ready to go back into the engine bay.
    [SIGPIC]
  10. #59
    95 Beretta LG8 Action
    Aug 2007
    267
    Check out my thread, I am up to similar business in a beretta. I just DD a bimmer. But anyway, rwd swap beretta with a 3500 t5. Camaro bellhousing and trans.
    http://www.beretta.net/forum/viewtopic.php?f=29&t=8329
    I want to see where you mount your P/S pump. I love the alt mount idea... I might hae to borrow that one. I dont like where the accessories are mounted on the f-bodies... too bulky.
    95 Beretta- Lg8 Daily Driver
  11. #60
    Quote Originally Posted by Barry View Post
    same for me, but i didnt want them sticking out the hood with f body stuff. as for the powersteering, i ditched it and have a block off at the rack.
    [SIGPIC]
