Page 3 of 14 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 133
Thread: 3400 N/A Monte Build Thread
  1. #21
    Mr. Common Sense mfuller's Avatar
    Nov 2003
    Loves Park, IL USA
    313
    Did you get a 245mm converter? Or did your car come saddled with the 258mm converter like L67/L32 cars?
  3. #22
    Nov 2008
    winnipeg manitoba canada
    1,212
    its the 245mm, the 258 were l67/l32 cars only
    the trans is in, the contrast is pretty different but it will look nice once i get everything else that i got in gold is in
  4. #23
    Nov 2008
    1,212
    So, i got all my parts back from the machine shop, custom rods, bearings, heads all ported and machined, you name it. how ever i seem to have lost all of my dowels for the cylinder heads, some how, and i need to get a frost plug for the rear which is another problem, it measures 34mm but they only have 35mm, so i got a rubber squish style, what do you guys think of those? and does anyone have an idea of where i could get the cylinder head dowels from aside piston ring? they are a discontinued part. i think i might have to go to the wrecker and rip off some heads
    If anyone has any assembally tips i'm all ears, i got plasic gauge to check all the bottom end bearings, and i got cheap oil with a break in aditive. thats all i could find in the city so i dont know if it will work out.
    Real updates hopfully this weekend with pics!
  5. #24
    I wouldn't trust a rubber core plug in an engine that I'm putting all that money into.
    Rock auto has them made by Dorman:
    DORMAN Part # 555104 More Information About this Part {Click Info Link for Alternate/OEM Part Numbers} Nominal Dia.: 34.3mm; Metric Dia.; 34.30mm; Steel; Height: 0.497"; Open End Dia.: 1.359"
    34.3mm Steel Cup
    DORMAN Part # 565104 More Information About this Part {#5651041} Nominal Dia.: 34.3mm; Metric Dia.; 34.30mm; Brass; Height: 0.497"; Open End Dia.: 1.356"
    34.3mm Brass Cup
    A quick google search for "cylinder head dowel GM 3.4" turned up this site:
    http://headbolts.com/chevy-v6-engine-fasteners.html
    2.8/3.1 V-6 dowel pin kit head to block 4pcs $2.50
    shipping is $ 6.95 there are no handling fees
    Assembly tips:
    Take your time, assembly isn't a race- the racing is afterward
    Use a beam type torque wrench on critical stuff, like caps and heads- they are more accurate than a clicker.
    Double check everything.
    Be generous with assembly lube- it's cheaper than new bearings, ect. (use your head though, you don't need 1/4 bottle per bearing half)
    I usually use cheap oil for initial start. After all, it's not staying in there long and you want stuff to wear in.
  6. #25
    Nov 2008
    1,212
    then indeed both frost plugs are junk that i had an option to. guess i'll try some dealerships tomorrow morning for the plugs and dowels. Thanks Pocket! I'm hoping to be able to drop this bad boy in come sunday
    Bob
  7. #26
    Good deal Just plan to spend most of tomorrow assembling. I know it can be built in a couple hours, but you have lots of money wrapped up in the powerplant for your car now, and I said it already but I'll stress it again, don't rush. That's one of the rules of the engine building books I've read lately.
  8. #27
    Oh yeah, be sure to rotate the crank after tightening each or every other cap (be it main or rod) just to be sure that the rotating assembly doesn't bind. If it starts binding in the early stages of assembly and you haven't been rotating it, you're going to have to figure where it started binding at and why after disassembling most of what you did. Not to mention, you are already putting crush into bearings, then taking it apart and reassembling. At that point you would want to worry about spinning a bearing after removing it after applying the crush from assembly.
  9. #28
    Nov 2008
    1,212
    With out further adieu... what ive been up to for the past 3 days
    oh yeah, oops
    If anyone can help with where these bolts go or what there for i would appriciate it.
  10. #29
  11. #30
    Nov 2008
    1,212
    and... small fitment issue's, the cross overs are not resting ontop of the trans bell housing due to the very first mock up, the flanges were on upside down, backwards and on the wrong side...simple fix tho, the mains are just tacked onto the flanges so its an easy adjustment, tomorrows another day
