Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 94 4T60E - slip/grab/slip/grab on take off
    OK. Good luck with yours.
  3. #12
    Apr 2005
    Waterford CT
    576
    That problem is a fun way to snap deferentials and axles. 4t65s do it to you need a rebuild.
  4. #13
    I have to manually shift the auto now to keep it from slipping. Lucas did not help. Is there another trans besides 4T60-e or should I stay with it? Also, anyone have opinions on trans shops? I'm tempted to look into swapping mine out. But, I cannot get much height in my garage. If you know of a good writeup point me to it. Thanks everyone.
    Quote Originally Posted by Dave96z34 View Post
  5. #14
    Here's a diagnosis: the 1-2 clutch drum o-ring seal is leaking and causing the clutch pack to temporarely lose pressure disengaging forward gear. Giving it gas builds up line pressure overcoming the amount lost to the leak. Transmission problems mostly show up at lower line pressure where fluid pressure is more critical to transmission operation.
  6. #15
    Sounds plausible. Thanks.
