Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Wiring help w/ Camaro 3.4L/4L60E in a 81 Chevette
    Feb 2009
    NW Ohio
    160
    Sure did!
    Check it out.
    NSFW language, my best friend was on the enthusiastic side that night, LOL.
  3. #12
    Haha freaking awesome!
  4. #13
    Feb 2009
    NW Ohio
    160
    I have a new issue to address, in order to get the speedometer working, should I be using a DRAC or a VSSB?
    My Chevette swap uses a 3.4 engine, e-trans, and PCM from a 94 Camaro along with a dash cluster from a 94 G20 van.
    The only other gauge that doesn't work on the cluster is the volt gauge, not sure why.
    Also, the G20 cluster has a white wire on the 13 pin that I can't find in Alldata or Mitchell's, not sure what that's for since the cluster doesn't have a tach.
    If any other info is needed I'll gladly supply it.
  5. #14
    Feb 2009
    NW Ohio
    160
    I picked up a DRAC from a 1990 G20 van today, will that work or should I keep looking for a VSSB?
  6. #15
    Feb 2009
    NW Ohio
    160
    Looks like I'll need a VSSB instead of a DRAC. I think it's because of my 4L60E.
