Page 19 of 19 FirstFirst ... 9171819
Results 181 to 187 of 187
Thread: Plans for L32/3X00 Hybrid
  1. #181
    Max tkoforpresident's Avatar
    Feb 2009
    Western New York
    689
    OK, well nobody knows the answers.
    That's cool. I'll just measure the ports myself and see if there is a difference.
    93 Firebird 3.4
  3. #182
    WrathOfSocrus's Avatar
    Jan 2008
    Jacksonville, FL
    319
    The 3500 ports are SMALLER on the LIM than a 3400. A while back I made the mistake of slightly widening the 3400 UIM before even looking at the 3500 LIM and had to port it out quit a bit to match. Luckily I didn't go crazy on the UIM.
    As for the gasket, you should be able to trim it up a bit. You can line it up to your TB with the bolts and press against the edge and that gives u a line to follow. Or if you have the throttle plate out you could probably mate it to the UIM on a bench and carefully go around with a knife to cut off what sticks into the opening.
  4. #183
    Feb 2009
    Western New York
    689
    Wow so the 3500 lim will have to be opened up to match the 3400 upper? I would have guessed the other way around. Thx for the intel.
    93 Firebird 3.4
  5. #184
    Jan 2008
    Jacksonville, FL
    319
    Fixed my post but you got it right. I'm not sure how far off the measurement is , but after seeing the difference in size I compared it to the 3400 LIM I noticed the difference. If you don't want to go crazy with porting you can bevel the edge and just blend it down a bit. As long as the air doesn't hit a sharp obstruction it should flow alright.
    When I opened mine up I used some cardboard (have also used left over gasket material that comes in a sheet for around $6, seems to form better) lined it up to the UIM, and pushed a screwdriver through where the bolts go and dropped the bolts in place. I pressed down along the edges of the ports to see the outline and cut it open with a razor. Then I went to the LIM and put down a couple strips of duct tape. Lined up the cardboard and carefully traced it into the tape with a razor. The duct tape is a life saver in case u slip while porting because it catches the file or burr before the mating surface gets damaged. Once you have your outline u can bevel the edge back at a rough 45* and then decide how much effort you want to put in to blending it down.
    I looked back briefly and saw your LIM looks like it is not ported. If your UIM is not ported then you probably don't have much material to remove. I think the reason the 3500 ports start out smaller is because the way the 3500 UIM is larger inside without runners, then gets sucked down the smaller port it increases velocity.
  6. #185
    Feb 2009
    Western New York
    689
    Yeah I don't want to port it so much but rather make the intakes uniform so flow isn't compromised. Either way I'm sure the setup I end up with will be twice as good as my old 3.4 intakes. Those things are a joke.
    93 Firebird 3.4
  7. #186
    Feb 2009
    NW Ohio
    160
    Ain't that the truth.
  8. #187
    Feb 2009
    Western New York
    689
    I took the time yesterday to grind off the letters/numbers from the top of the 3400 upper intake. I also dropped it off at a friends house to have it slightly ported/smoothed to match my 59mm TB. Once he's done with it I can clean it, paint it, bolt up the TB/egr block off plate, and get some pics for you guys.
    Should look good, especially with the black powdercoated tb, and stainless steel bolts.
    93 Firebird 3.4
