Page 9 of 9 FirstFirst ... 789
Results 81 to 86 of 86
Thread: Entering Closed loop faster with $A1
  1. #81
    5,233
    well, since your cam doesn't generate a lot of vacuum at idle, we raised the threshold of where the ECM will start thinking there is a problem with the MAP sensor.
    this SHOULD prevent a MAP high DTC from being set during it's test period, at least it will as long as everything is working properly. if the MAP itself goes completely nuts(reading above the 91kPa when in a near idle condition), it should still set the code. much better than simply disabling it.
  3. #82
    Max tkoforpresident's Avatar
    Feb 2009
    Western New York
    689
    and i've got a spare map sensor in case it is the actual sensor being goofy.
    I'll burn this chip and then let you guys know the results.
    thanks
    93 Firebird 3.4
  4. #83
    Feb 2009
    Western New York
    689
    Hey, so far so good. I installed the new chip, jumped the bird (battery was dead) and let it idle for a couple minutes. Then the moment of truth came and I popped it into drive and let it sit there for 5 minutes... Didn't stall out once. Reverse was fine too.
    I don't want to declare it after one single test but it looks like the problem *might* be fixed.
    How come we didn't change the map threshold sooner?
    Ben has some explaining to do
    Robert, thanks a million my friend. Let's hope we never get that code again.
    93 Firebird 3.4
  5. #84
    Dec 2009
    Pittsburgh, PA
    766
    HORRIBLE idea... especially since A1 is entirely hacked, every single byte of calibration being adjustable as if we were GM calibration engineers themselves
    Ultimately, aside from the concept, I wouldn't do it to my engines PCM. I would find a much better solution. Resistors are more like road side quick last ditch effort to get home kinda thing, i guess. lol
  6. #85
    Dec 2009
    Pittsburgh, PA
    766
    Quote Originally Posted by tkoforpresident View Post
    That's great. Good job, I'm bringing my engine back to life after sitting 8-9 months. Winter to Summer temps too, outside. Crazy NE weather, does a number with time.
  7. #86
    Feb 2009
    Western New York
    689
    yeah thanks man, feels good to get the bird fixed up.
    Of course as soon as I get the bird fixed my explorer starts acting up... brakes are grinding.. not good
    93 Firebird 3.4
