Page 1 of 6 123 ... LastLast
Results 1 to 10 of 58
Thread: Homemade Pneumatic Engine Pre-Oiling Machine
    Mar 2009
    usa
    1,328
    I am in need of some help and technical advice on the following idea for a new build:
    On the wings of the success of designing, building and proving out "The FrankInjector Machine" for the thorough cleaning and re-conditioning of Fuel Injectors, I have it in mind to borrow the Pneumatic Section of the aforesaid device (or build and use a new one exactly like it) and create an Operational Pneumatic Engine Pre-oiler that will obviate the need for the removal of the OPD (Oil Pump Drive) and the temporary insertion and use of any Mechanical or Electrically Driven Pre-Oiler. If made well, this device could save many extra hours of work, including the need to remove engine sub-sections or perhaps an entire engine to accomplish this task.
    CLEAR BRAIDED PVC HOSE 3/8 INCH 250 PSI 25 FT HA16-025
    http://cgi.ebay.com/CLEAR-BRAIDED-PV...item5641b0a8a1
    CompCam Engine Break-In Lubricants
    http://www.compcams.com/Products/CC-...ants%27-0.aspx
    The Pre-Oiling Machine would find its point of oil entry to any engine block at the position of the Oil Pressure Sending Unit. This would require the temporarily removal of the OPSU to allow the high pressure clear re-enforced PVC tubing and fitting delivering the Engine Break-In Oil and other lubricants as needed, access to the engine oiling system at its pressuring inception point.
    I am suggesting that no other modifications are necessary to the existing mounting stand that I use to hold "The FrankInjector Machine" hardware. In lieu of having to start designing something from scratch and having to change over to a Very Large Volume High-Pressure Oil Container, Instead, I am suggesting that I can employ that same Aluminium Cylinder at present being used to hold the EFI Cleaning Fluid and simply fill the cylinder with the required mixture of Engine Break-In Oil and Special Additives to protect the precious new bearings and rings in fresh engine builds or revive the vacant or dry oil galleries and bearing surfaces in engines that have been dormant for extended periods of time. The volume of this oil would necessarily be much greater than the small Aluminium Cylinder can hold, so instead I would attach a coil of high pressure (proofed to 250 PSI) clear, reinforced PVC hosing 25' long with a .375" Inside Diameter.
    The clear coiled hosing would serve three purposes in this design: (1) The 25" length of hose would allow for a substantial quantity special, premixed lubrication to fill up that long length of tubing and act as the means of extending the storage capability of a sufficient quantity of lubricant instead of requiring a larger primary oil storage container. (2) The clearness of the tubing would allow the User/Mechanic to actually see exactly where the fluid moves along or ends and/or any air pockets that may be present in the line. As long as the Aluminium Cylinder is constantly being refreshed with the oiling mixture until the tubing hose is filled up, no air can invade the PVC line, assuming that the filling and refilling processes occur first with the purging of air from the hose all the way up to the attachment fitting and then prior to its being threaded into the female port of the Oil Pressure Sensor Unit located on the Oil Filter Manifold. (3) With such a long length of hose, it would be no trouble to move the stand supporting all of this apparatus close enough to either an engine stand or a vehicle very near thereto, and still have enough length to be guided along and inside any engine compartment for the purpose of easily attaching the PVC hose to the vacant female Oil Pressure Sending Unit port.
    I have used metered pneumatic sourced by a typical air compressor tank and delivery lines to accurately and reliably pressurize the EFI Cleaning Fluid during all the regimes necessary to emulate normal fuel pressure for the 3.4L engine and the same will be possible using the clear PVC hosing which has been proof-tested to 250 PSI: well above the rated maximum oil pressure attained with the in-dwelling mechanical oil pump of our V6 engines.
    The information and guidance I require knowing for this project is as follows:
    (1) What is the volume in fluid ounces of a length of PVC hose measured at 25' L X .375" ID...?
    (2) What is the Maximum Recommended Delivery Pressure of any Pre-Oiling Fluid Mixture sufficient to deliver enough special lubrication to all of the engine bearings and inner surfaces being protected... and NOT burst the Oil Filter Cannister ( if that needs to be considered in this design} ?
    (3) What is the volume of Oil in Fluid Ounces required to fill all of the Empty Oil Galleries and Oil Passages as well as all Bearing Surfaces inside the average V6 Engine Block? At a minimum this information is critical in avoiding pre-maturely de-pressuring the aluminium Cylinder before actually reaching all of the areas requiring proper lubrication.
    (4) What is the size of the thread/pitch count of the high pressure fitting on the Oil Pressure Sensor (Sensing Unit) and is there a swivel design available of this type of fitting that allows for high hydraulic pressure and provide the ease of being inserted and screwed tightly inside the Oil Filter Manifold?
    If you have seen the results of the design and development of "The FrankInjector Machine", then you know that when I put my mind to a project... I will make a sincere effort to ensure that it really works as intended. So I would value any and all constructive ideas and criticisms on its design and its improvement as things progress.
    Mar 2009
    usa
    1,328
    In order to test whether this device will actually work properly, I intend to employ a stand-mounted 1995 L-32 3.4L in the process of being re-built and use a single valve cover and cork gasket divided in half and fitted to the outer lower angled portion of each engine head. This method will allow for the User/Mechanic to observe the progress of the oil making its way through the pressurized oil galleries lower in the engine and then up through the hollow push rods to lubricate the upper portion of the valve train.
    I will interpret the even and steady flow of the new oil up through and over the entire valve train on either side of the engine as a strong indication that all of the air in the oil galleries in the engine block has been purged and that the engine is being successfully pre-oiled. With the critical parts thus coated and protected, If the oil makes this journey as described, I will slowly turn the crankshaft through several rotations to ensure that there is an even distribution of the special lubricants on the camshaft, camshaft bearings and the connecting rod bearings. The low speed and minimal number of cycles should all help to ensure an even distribution of the special oil on all internal engine parts.
    When the engine is finally buttoned up and installed in the car with a crankcase full of the same special break-in oil and additive mixture, I'm anticipating that it can be safely started normally and run up to a steady 2,000 RPM for 25 minutes to perform the necessary initial camshaft and lifter break-in period. The pneumatic pre-oiling procedure using this proper engine break-in oil with plenty of ZDDP and other additives should dramatically reduce the likelihood of any damage occurring to the new engine parts that might suffer from having empty oil galleries or finding dry engine parts in harsh metal-to-metal contact and either wearing out suddenly or seizing pre-maturely.
    I intend to document and post each step of these procedures via digital images and videos and will post the links to my photobucket for the forum members to examine. If I have overlooked or missed anything needed to make certain this process will work right... please chime in and let us all know.
    Umm, I usually cut power to the coils and fuel pump and just crank it via the starter till i get pressure... But I've been known to do things a little haywire in the past.
    6,264
    I usually do the same as Mars, but instead of pulling the OPSU, why not just screw it in where the oil filter goes and pump it in from there? You will get more volume through there and you don't have to worry about teflon taping the OPSU and trying to install it again.
    Surrey, BC, Canada
    5,830
    You can buy said kits from several sources. Engines with crank driven pumps require the use of an external pre lube system. Garage built systems can be made from an old bucket and an oil pump attached to the lid and driven by a drill. A supply and return hose can be attached to an oil filter adapter screwed on to the motor.
    Apparently this stuff works really well too:
    http://www.lifeautomotive.com/Products/ATE15001.asp
    RIP - 94 GP SE
    DD - 95 GP SE
    Fun - 91 Mercury Capri XR2 Turbo AWD Conversion
    http://www.werbatfik.com
    Max tkoforpresident's Avatar
    Feb 2009
    Western New York
    711
    oh come on guys don't discourage him
    I for one would love to see another one of Bob's inventions.
    93 Firebird 3.4
    RWD FTW!!! 2.8-350TBI's Avatar
    Sep 2009
    Springfield, Oregon
    351
    Do it. Just use regulated air acting on oil to get it into the block. Thats what we do in my diesel tech program. We call it a pig lol
    Quote Originally Posted by Mars View Post
    Haha ^ Wrong Wheel Drive.
    No 60šV6 at the moment
    Mar 2009
    usa
    1,328
    Gentleman...once again, your kind collaboration teaches me my craft. It is funny that in this situation, what you have guided in my thinking has prompted me to do the reverse of how I originally envisioned the base design of the first "FrankInjector Machine" where I had thought to create an elaborate electric pumping system involving an automotive fuel pump and some overly complex re-cycling and containment "aquarium". What it ended up using was the Aluminum container and the use of compressed air as the driving force to make it all work. But in this case, thanks to this early discussion, the reverse is true and I think that instead I will use a small electrically operated, inexpensive liquid pump:
    http://cgi.ebay.com/3-8L-12V-CPU-CAR...item518c930960
    Pocket-Rocket's idea about making a more direct fluid connection via the threaded oil filter interface makes more sense than trying to force many quarts of the special break-in oil through such a small and inconvenient orifice as the one fitted in the Oil Filter Manifold for the Oil Pressure Sensor Unit. Geoff Moore's (betterthanyou) suggestion about "The Bucket" prompted my search for a suitable, small liquid pump and the one linked above seems to meet all of the requirements, including working off of 12 VDC and having a 20,000 hour MTBF... all for less than $25.00.
    The only other addition I will consider is that after having run this pump long enough to see the new lubrication percolating over the tops of the rocker arms, I intend to attach several powerful scavenged computer hard drive neodymium magnets to the outside and bottom of all oil filters, first to the initial "filled to the brim" camshaft break-in oil filter and then remove and replace them onto the second oil filter installed after the completion of the first 30 minutes of engine break-in time. That would all but eliminate the chance for any freshly machined areas and new parts from shedding ferrous metal particles and having the chance to become buried deep into the softer Babbitt bearing surfaces.
    So all I will require in the way of materials for this project are:
    1. A shorter length of the reinforced clear PVC tubing and some S/S screw clamps
    2. The new fluid pump (the one I'm ordering works either with oil or water)
    3. A threaded Oil Filter adapter to attach to the PVC tubing
    4. Two leads and some large alligator clamps if a car battery is used (Or SuperDave & Robertisaar's idea for using an ATX Power Supply that worked out so well with "Frank")
    5. A stable plastic mixing and holding container large enough to hold a gallon of special lubricant
    6. A Toggle Switch
    7. Two or Three Neodymium Magnets
    8. A Bifurcated Valve Cover and Cork Gasket (Just a little humor here... I mean for it to be two halves of each item)
    Geoff's observation about "the return-recycling" portion of this design will not be required, since all the special oil being pumped through for the engine priming will simply cascade over the valve train and then gravity pour down through the open oil return channels and drop inside the crankcase. When completed, a four quart priming of the system then requires only one additional quart of the mixture be added to the crankcase to top the things off and the engine will be ready for its initial start-up.
    6,264
    Sweet This thing should rock just as much as FrankInjector does.
