poly engine mounts
does anyone make poly motor mounts for the dohc w-body
10-17-2010 03:38 PM
Jake91
I don't know if anyone makes them for the LQ1, but from my experiance with polies on f-bodies they are much harder than stock.. You will likely be giving up a little comfort will them as well.. The harder the mount/bushing the more vibration and sometimes noise that will be transfered to the inside of the vehicle also.. Many times polies will squeak and or make chattering sounds over bumps and so forth..
As with anything tho it's always up to the owner and what you like/want..
Fast FWD performance made some. There have been a few guys who did their own DIY solutions. ZZP and Intense also had them for certain applications.
Tim
325 whp 350 lb-ft
