Results 1 to 10 of 20
Thread: Epping NH 12.67@107
    Dec 2005
    Plainfield CT
    3,192
    Epping NH 12.67@107
    About time.
    Finally hit my 12 sec pass... I got the 12.97 I wanted with no changes since my 13.078 run so that made me happy. Then the following day I soaked the bottle in the sun and got her up to 900 PSI, Its amazing the difference it makes. The jets are now delivering the amount of nitrous it should be, so I think my WHP gain went from what I used to get (60) up to the rated 100 of the shot.
    Rolled a 12.67@107.47 Unfortunately the last run of the day I had shifting issues and the track was wicked slippery so I aborted to get a 13.2@91 But the day prior, it was the 12.97, 12.85, and a 12.92 all in a row. So consistent 12's is NOT out of the question.
    Here is the 12.67 and 12.97 slip, I left the 12.85 in the car, but I'm uploading the 12.85 and 12.67 vid's
    I just need to get the LSD rebuilt for next year and maybe beefed up to be a bit stronger... Right side of car is caked with rubber, absolutely nothing on the left and you can see the tire only spins when in the water box.
    Dec 2005
    Plainfield CT
    3,192
    Awesome!
    11's or Bust...
    Feb 2008
    Paynesville, MN
    196
    Nice times!
    My Garage
    RWD FTW!!! 2.8-350TBI's Avatar
    Sep 2009
    Springfield, Oregon
    348
    Congratz!
    Quote Originally Posted by Mars View Post
    Haha ^ Wrong Wheel Drive.
    No 60šV6 at the moment
    Nice to see the NA's doing 12's, Congrads man. I hope to join you in the 12s club next year.
    Stage 2 Comp WOT-TECH heads, upper and lower intake P&P, street/strip cam, Custom pushrods, TCE LS Lifter Springs, Dimond Pistons 10.7:1, 65mm TB, stage 3 custom cold air intake, heat shield(only for Heat protection on Temp and MAF sensor), DHP Tuner, Adj FPR, #28 injectors, MSD ign coils, talyor wires, S&S header, S&S high flow cat, borla cat Back, all ARP studs, TCE double timing chain with crank kits, Cometic head gaskets, A/C deleted, HF water pump, and so on
    Dec 2005
    Plainfield CT
    3,192
    Quote Originally Posted by ShieldsM View Post
    NA's um not quite...
    Its a Sprayed motor.
    12's with a 4t60e n/a is going to take a lot of motor.
    Doesn't matter that you are using NOS, it is still N/A. I need NOS to hit 12's too
    8,981
    Nitrous is considered a type of forced induction, not NA...
    Jan 2007
    Ft Lauderdale, FL
    4,270
    Nice times, Jon! Car is looking good as well
    Lulz.
