Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: trying to hack away at 3500 file
    while i have NO issues with that ideology, are there any 1.5BAR MAP sensors out there? if so, the PCM would still need to know it and then scale everything accordingly.
    if there aren't and there is only 1,2 and higher, WTF is the point of going up to ~1.5BAR? the 1BAR can't read it and a 2BAR should read to ~210kPa... so why 140?
    was the LSD making rounds that day? or did someone not scale the VE tables correctly when they hacked through it? if you had a testbench, it would be easy enough to determine, but i find it more likely that the 4 extra entries in that table are actually 25,35,45,55 kPa. above 100 just doesn't make sense in a program that can only see up to 100...
    I agree...
    I'd think that the 25,35,45 and 55 would be there to increase the VE resolution, $A1 is like that...
    Attached Files Attached Files
  3. #12
    5,233
    more or less, exactly what i was thinking...
  4. #13
    Dec 2003
    San Antonio ,TX
    392
    Can you post the findings here, link not working.
    88 Beretta GTU, IHI GM-8 turbo (Duramax). 2spd 3t40 . 90 Black ASC/McLaren TGP, awaiting 4t80. 2003 Grand AM se 3400/4t45 daily grind.
  5. #14
    2006 lx9 3500
    I have been following (sort of) this thread with interest and wouild like to ask about ltft tables. Any info you can share?
