Results 1 to 3 of 3
Thread: 3500 LX9 Injector Constant base #
    Spinning out of control Weatheralls Auto's Avatar
    Dec 2009
    Toronto Ontario Canada
    537
    Looking for 3500 LX9 Injector Constant base #
    I have found this modified .bin that opens in DHP and Tiny Tuner, but the numbers are different between the 2 apps and I am wanting just one number to start off with.
    Attached Files Attached Files
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
    I am by no means an expert with this. but I am using HPtuners and in my 2000 grand am la1 pcm there isn't any option for injector constant base. I'm just assuming your doing this to your 2001 Impala pcm.
    5,233
    referring to the "seconds per gram" value used in the IFR(or whatever it is) table?
