Page 5 of 36 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 353
Thread: My 89 Camaro Project
  1. #41
    This car has always been an auto...
  3. #42
    Dec 2005
    Plainfield CT
    3,192
    I was going to say, no where did you say they switched it to a 5-speed with the v8 swap. But I was waiting for you to chime in.
  4. #43
    I don't think i'm going to use the tubular K member, a local guy wants it for his LSx swap and has offered me a nice trade deal. 2 Jegs "Sport Star" 15x4 skinnies with brand new Front Runners and some cash. This will help me to get a trans, converter and maybe a shift kit.
    Then i'd just pick up some matching 15x10 or 15x8 for the rear to use with drag radials.
    I did some measuring last night and it looks like i can just mod my stock K member for the needed pan clearance.
    BTW, no pics but i pulled the rear end out last night. Dropping the gas tank tonight to get ready for the install of a Sy/Ty pump.
  5. #44
    Apr 2008
    Muscatine Is
    13
    your moving right along.
    Keep up the good work.
  6. #45
    Picked up my 700R4 this morning, it's pretty clean. No idea on the miles but the fluid looks good. Came out of a 93 Camaro. 93 was the last true 700R4 in the Fbodies, 94 is when they started changing things.
    It looks like i'll have no problems putting the FWD engine on this trans, there is no notch for the starter so i'll just have to modify a stock V6 flexplate cover.
  7. #46
    first ever 700R bolted to a 3500?
    Spohn K member installed:
    Got a few things to take care of before i can get the engine/trans in to make mounts. Hopefully soon...
  8. #47
    8,981
    I didn't think you were using that K-member? Glad to see one of us is making progress...
  9. #48
    i had it, nobody locally wanted it so i just went ahead and put it in.
    It's 8 lbs lighter than the stock one, but gives me a lot more room to work.
  10. #49
    Looking good, but shouldn't that crank be stored upright?
  11. #50
    It's a junk crank
