Page 30 of 36 FirstFirst ... 202829303132 ... LastLast
Results 291 to 300 of 353
Thread: My 89 Camaro Project
  1. #291
    Dec 2005
    Plainfield CT
    3,192
    Prime example why gas is so expensive, Dave is using it all...
  3. #292
    Feb 2009
    NW Ohio
    160
    Quote Originally Posted by 3400-95-Modified View Post
    I'm sure he wouldn't mind if it was all being burnt
  4. #293
    And I thought my camaro ran rich.....hard to believe there is an o2 sensor under all that, lol.
  5. #294
    picked up the new WBo2 today, $51 at the parts store. Just need to get it back in, wire up the other o2 and then try to figure out my trans issues and it'll be back on the road.
    I had to steal the battery out of it though, the Duralast gold in my truck died and stranded the family and I at Walmart tonight.
  6. #295
    Winter sucks.. so to pass the time i bought some new goodies...
    Pair of Hooker Aerochambers, X pipe and a Holley harness for my Commander 950 ecu.
    I want to clean up the wiring and this harness should do just that.
    Did i mention that i only paid $16.50 for each Aerochamber?
    I bought display models, all i need to do is pick up some sheet metal, cut out a patch and weld it in. Normally they are about $70 each.
    Here is the inside of one...
    I'm sure there are more on ebay, this is a good opportunity for anyone to get a badass muffler for very cheap. As long as you can weld it you're good to go.
  7. #296
    Feb 2009
    NW Ohio
    160
    That's a great tip Superdave, thanks!
  8. #297
    Dec 2005
    Plainfield CT
    3,192
    HRMMM... I was planning on redoing the exhaust on Pinky this year since it's started to crack in some spots... Too much lope and shaking... lol
  9. #298
    Did not know you could have too much lope!!!
  10. #299
    The Situation geldartb's Avatar
    May 2004
    N Brookfield, Ma
    1,920
    looks like they got a bunch of them
    http://www.ebay.com/itm/Hooker-Heade...item5198daf822
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
  11. #300
    Yep, same guy. He also hooked me up with the 950 Commander harness.
