Results 1 to 1 of 1
Thread: rebuilt 94 3.4 for sale
    Aug 2005
    Kelowna, BC - Canada
    Surrey, BC!!!
    94 Camaro engine, will work in s10 with carb swap. bottem end rebuilt by dunrite in richmond, heads by HU. Engine was destined for my miata but I had to throw the project away. need to sell. I have spent probably $4000 on this.
    completely rebuilt engine.. new mains, new rings, etc. heads too... new valve guides, etc. headwork: smoothed ports and gasket matched, bowl blend.
    performance parts:
    comp cams 260H
    lunati springs (i think i have new comps as well)
    magnum 1.6 roller rockers
    SI stainless swirl polished port-flow valves (backcut at machine shop) paid $600 for them
    mellings high flow oil pump
    NGK iridium plugs
    ARP head studs
    underdrive crank pulley
    180* stat
    Permacool remote oil filter adapter and cooler
    custom exhaust header flanges from 'betterthanyou'
    brand new starter!! new water pump, all new gaskets, timing chain, its all been done.
    I have the stock flywheel and used clutch as well... engine had 200k on it at time of rebuild... purchased from wrecker.
    I also have T5 transmission I'm willing to sell with it if iterested.
    Make a reasonable offer, Local sales only! greater vancouver I may be able to deliver, otherwise you pickup.
    engine as pictured except no power steering pump or alternator anymore.
