Results 1 to 7 of 7
Thread: 92 grand prix key stuck
    So, the gf's car has been having problems with neutral safety switch- so I thought. Every once in a while, it wouldn't roll over without putting it into neutral to park a couple times. Now, it won't roll over and the key is stuck in the ignition. I can hear the ignition lock trying to cycle by pushing on and releasing the shifter button. Any ideas? Would the ignition lock keep the car from starting and releasing the key? How bad are they to replace on these cars?
    The car is a 92 grand prix with the 3.4 dohc with an automatic and console shifter.
    Thanks
    88 Beretta GT
    69 Corvette
    79 Mustang Ghia
    95 Cutlass Convertible
    alright, so I got the key to wiggle out later yesterday. And today I cleaned the connector on the trans for the neutral safety switch (it was pretty corroded). Now, it will roll over no problem but it's not firing. Is whatever that's keeping the key in the ignition a possibility for being a culprit behind the motor not firing?
    88 Beretta GT
    69 Corvette
    79 Mustang Ghia
    What's keeping the key from wanting to be released? I also noticed that the shifter release doesn't like to spring back very well- allowing you to select a gear without pushing in on the button.
    88 Beretta GT
    69 Corvette
    79 Mustang Ghia
    Jun 2005
    Kelowna BC
    231
    Replace the cylinder and lubricate the shift release mechanism. Not to difficult to take the cylinder out you need to disassemble the steering column shroud to get it out.
    http://cgi.ebay.ca/88-90-91-92-LUMIN...item56371d0778
    1991 Pontiac Grand Prix GTP / 3.4 DOHC
    Thanks, What would be best to lubricate the shifter mechanism? I used some white lithium grease and it still isn't coming all the way up too quick.
    88 Beretta GT
    69 Corvette
    79 Mustang Ghia
    Jun 2005
    Kelowna BC
    231
    The old grease should be cleaned off first as it's probably gotten gummy and sticky. Same as what happens on the park brake lock... Anything that removes grease should work. Just make sure it's safe to use around plastic and doesnt stink to bad. Lithium grease works good for that sort of thing. Contrary to what lazy old guys think WD-40 isn`t a universal problem solver.
    If your looking for a cheap place to get it replaced you can call these guys and see if they have the part you need http://www.tricityusedcars.com/336223.html if it isnt there they might have an aftermarket. They just recently did some work on my car and it was alot cheaper then any place I went before I found them. good luck
