Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Saggin' Transverse Spring
    What parts do you guys use that have the transverse spring suspension to lift it up in the back? I got one on my 91 GP and it sags like you know what. Let know because everytime i look at it, it pists me off.
    I believe you can buy new pads for the spring perches. Should give it a bit of a lift.
    When I replaced my rear struts with gas charged ones the rear of the car perked up just a bit.
    1994 Corvette
    LT1/ZF6
    2006 Dodge Dakota 4x4
    3.7/42RLE
    ok now what does this look like, where can i get it and how much does it cost? What's involved installing them?
    5,233
    i would think you could find them at rockauto...
    at this website, what do i type exactly to view this?
    5,233
    i believe they are refered to as leaf spring bushings...
    ok i saw on the website a transverse isolator pad. do you know how they are installed and exactly how do they push up the height of the rear?
    isolator pad sounds like a pretty good technical term for it.
    95 Grand Prix GTP 94GPGTP's Avatar
    Apr 2007
    San Antonio,TX/Beecher,IL
    593
    I have a FE3 rear spring from my 95 GTP. And I can remove the spring from my Z34 parts car if u wanted one. I believe the Z34 spring is FE3 as well. Just change the spring and it will raise the car back up and give it a better ride. Or just cut a coil and a half off the front to level it out.
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
    Banned
    Oct 2005
    Hamilton, Ontario, Canada
    649
    Do NOT cut coil springs!!
    Very dangerous to begin with and ...well that is just GHETTO!
    Replace the insolators, or swap out the spring. Heck do both!
