Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: new track times
    Aka Mr. 5th Motor
    Sep 2006
    Muscatine, IA
    425
    new track times
    actually i think these are the first track times i've ever posted on 60*v6 :P anyway, with the old 3400 best was a 14.5 spinning on drag radials.... now i've got the same cam(my same old 1617 grind from the old sheet) in my 3500.
    New motor went in about a week before the v6z24 bash, slips weren't worth damn then b/c street tires just get blown away. Got a set of slick to use last night.....
    made 4 runs, this is in order first to last
    13.883 @ 100.09 - 2.002 60'
    13.756 @ 100.57 - 1.984 60'
    13.794 @ 100.27 - 2.089 60'
    14.156 @ 99.31 - 2.046 60' - clutch was slipping like crazy
    Fastest N/A Sunbird FTW
    slips are here:
    http://www.v6z24.com/registry/v6bluebird
    Cammed 3400 --> 224whp 210wtq
    Cammed 3500 --> ???
    1 of 5 3500 J-Bodies
    5,233
    might be the fastest sunbird, period....
    that one guy
    Feb 2007
    molalla, OR
    627
    nice times! i still have yet break out of the 2.0 60ft. what kind of tires/pressure are you running? using 4th gear?
    mods - last updated 3/29/09
    Aka Mr. 5th Motor
    Sep 2006
    Muscatine, IA
    425
    i was running 24.5-8x14 slicks, at 18lbs. nice burnouts to warm them up, dumping at 4k. clutch was slipping, which was pissing me off, since it's pretty new(but it is broken in so it should be fine). guess EZ stage 3 just isn't enough. oh well, not the end of the world. i'm thinking i could wring a 13.5 out of it if i had a clutch that held better and pumped my rear air bags up a little more, i think they were at about 25lbs.
    also, i was JUST getting into 4th. i was gonna see about winding 3rd out until i hit the 7k limiter, to see if it'd take me through the traps, but i decided not too since on that 4th run the clutch slipped pretty bad. wish i had the quad 4th gear still..... but the 3.94FDR was too crazy.
    Cammed 3500 --> ???
    that one guy
    Feb 2007
    molalla, OR
    627
    nice! im gonna have to try a harder launch. i dont even know how i would explain my launches, i just go for it but i can repeat it 100 times if i wanted lol
    Build your transmission with the quad 4th and 5th gears, like I did. I believe only 90 and 91 have the non fuel saver 5th gear. Basically it is now a W41 gearset with a 3.61 fdr. It was a pain in the ass, lol, but I think it was worth it. What kind of lsd are you running? EP?
    Aka Mr. 5th Motor
    Sep 2006
    Muscatine, IA
    425
    no LSD but that's what i would go for if i got one, an E.P.
    also, i have a 93 w41 tranny sitting but i don't have the money to pay to have them frankensteined and i can't do it myself, i tried to take apart a junk 88 hm282 to make a lamp and i ended up cracking the casing apart to get the pieces out. it's a badass lamp :P
    Cammed 3500 --> ???
    got any of the gears from that left? i need to make something to destroy eproms at work and some nice heavy gears would work good..
    5,233
    destroy EPROMs? junked ones? i have a hammer i made a few years ago, weighs almost 5 pounds and has a nice edge on it, cracks through them in one or two swings.... my regular 16oz hammer took dozens, until i grabbed a nail and pierced through the PROM...
    i usually have 500-1000 to destroy at a time, a hammer would take all day.. lol
    I built this, it works but a gear crusher would be more fun.. especially if i hooked a motor up to it.
