Megasquirt 1 - msn extra code tune files
Got a request for my tune files so i will post them all here
this tune is using ms1 msn extra cde
rwd iron heads, and boost, ve maps are setup for 18 inches of vacum at idle
and 21 psi of boost
spark tables ( good t 21 psi on 93 pumpgas/ abve 14 psi meth injection is highly advised,
i need to screen sht the ther ones and then put all the files in a zip file t uplad them ill do it in a bit
03-23-2009 09:22 PM
Procrastinator
