Results 1 to 5 of 5
Thread: setting megasquirt timming offset
    Mar 2008
    Saskatoon SK. Canada
    3
    I have a msII v3 running a '03 3400 with dis in a fiero, I want to set the timing offset. I borowed a cheap timing light but I can't find the timing marks on the damper. I don't know that much about setting the timing, so if you could give me some pointers I would really apreciate it. should I get a digital timing light? any recomendations on brand/model?
    Thanks
    '86 fiero-'03 3400 running on megasquirt II v3.
    95 Beretta LG8 Action
    Aug 2007
    267
    Because that motor came with dis they dont put timing marks on the pully anymore...
    http://www.megamanual.com/ms2/GM_DIS.htm
    Does that help at all?
    If not, you could use an external trigger that WOTtech sells. That way you can manually offset the timing. But im sure theres an easier way... I havent started tuning yet.
    95 Beretta- Lg8 Daily Driver
    Accelerating uphill in OD Azrael's Avatar
    Apr 2005
    Selkirk, Manitoba
    763
    Most tuning files I see for the 3x00's have a 57 degree offset. I'd wait and see if someone else can confirm that though.
    1995 Grand Am SE
    My MS setting for my 3400 in a 93 cavy
    Jan 2007
    Ft Lauderdale, FL
    4,270
    57 to 60 degrees. Same as when we us a V8 mask on a DIS vehicle with OBD1
