Results 1 to 4 of 4
Thread: Removal of Valvebody 4T60E
    Hello,
    Just wondering whats involved in removing the valve body in a 4T60E?
    Thanks,
    Dan
    Dec 2005
    Plainfield CT
    4,359
    make trans side cover accessable, either by dropping that side of the driveline down or removing it.
    1 Remove side cover
    2 Remove wiring harness from VB
    3 Remove pump housing
    4 Remove valve body
    If you've never gone into a 4t60e yet, I will suggest buying at ATSG book from ebay, it will help a lot telling you which bolts to remove and what to torque them to going back in. Its a little too much to explain in a post.
    Got Lope? New vid coming soon... Spring 2015!
    3500 Build in progress, XFI Cam 218/230 .050 dur .570/.568 lift 113LSA
    12.61@105 Epping NH Oct 2015 Nitrous 100shot 13.58@98.8 N/A 3200LBS
    2007 Legacy GT Limited 5-speed 3" Turbo Back, Stage 2 - 255whp/310wtq
    Dec 2003
    San Antonio ,TX
    453
    That and some Trans assym grease. Helps keep those dam balls in place.
    Dec 2005
    Plainfield CT
    4,359
    good call, i forgot about that.
