Megasquirt Piggyback
I know there are a ton of theads on megasquirt, but all the ones I read are a couple years old, so I'd like to hear what the latest and greatest opinion is on what to do.
Quick history lesson: I have a 95 Beretta with soon to be 3400/turbo/manual (currently have a 3100/4t60 but buying one with 3400/manual) built my turbo set up for the 3100, but going to use it on the 3400 instead. Should also add that in my state SES light has to be functional (comes on with bulb check then goes out) and has to pass rolling sniffer test. My plans with the bulb check is to clip the wire for the SES and spilce into another one one that comes on with the bulb check and goes out. (that's if I will have a solid SES light). Just hoping with the right tune and cat that it will pass...
Was going to just use my 255 lph pump with 10:1 FMU and stock injectors, and not use a tune because my car is OBD 1.5. But keep reading and reading and talking and talking to people... so I think i'll just bite the bullet and go tuner, asking around my 2 options are really obd2 swap with DHP or Tunerpro or megasquirt, but ive been told that megasquirt will have problems with my IP cluster. So piggy back my stock ECM with megasquirt is the best option right?
So to the reason that I made this thread. What megasquirt will be the best route to go (for the money) and for boost. I will build the board myself to save the little bit of cash to do it, and so incase something breaks later on, I can fix it myself. So what version do you guys suggest? I would like to be able to adjust spark/fuel (at least). But i remember reading on some board that with some MS you can adjust your wastegate, BOV, and have outputs for things like NOS and water injection.
Thanks for you input. Let the bashing begin
And FYI megasquirt.com is not a place to buy a megasquirt tuner...
95' Z26, ported/cammed 3400/3500, OBD2, 282. Slowly emptying my boxes..
05-23-2008 01:21 AM
Mr. Orange.
It may be possible with additional sensors and sharing of some sensors for both MS and the stock ECU to work and if the fuel/spark/etc is dead on the stock ECU won't throw a code.
If I went this route (we don't have the SES looked at) I'd just keep whatever needed for the stock ECU to control my auto and possible the IAC. And let MS do the rest.
For the versions, no idea, I don't know much about MS in that regard. Anyone suggest a route to go with?
Accelerating uphill in OD
I was tempted to go the megasquirt + FAST transmission controller route but I'm opting for the OBD2 swap and chipping in for an HPTuner with 5 other guys. A little cheaper that way and I trust an OEM PCM over anything I build.
Is it possible for an aftermarket ECM to completely take over the fuel injectors/ignition system without the original PCM bitching? It might not like going past it's target redline if you allow it to with MS for example.
Mr. Orange.
Making it work
I'll sell my MS1 for $150 professionally assembled. V2.2 board, set up for DIS.
ou can use it to control only spark and fuel, sharing sensors. Some sensors can't be shared, but that's covered in the MegaManual.
Interesting...I'll have to give MS another look.
Well I was convinced. Ordered a MS2 kit. The tuning section of the Megamanual is a little intimidating though.
Mr. Orange.
Sweet! So you're gonna piggy back and let the stock ECM shift the trans! Awesome, keep us updated! I want to do this too sometime but it will have to wait too busy right now.
Im intrested as well, ms seems like a very good option for us 94 and 95 guys.
95 Beretta- Lg8 Daily Driver
I'll definitely try to document my progress in another thread. So far I only have the bare minimum ordered (MS kit and a laptop).
The nice thing about piggybacking with MS over an obd2 swap is being able to avoid having to rewire the engine bay, swapping the ABS pump and evap solenoids. Plus the process is mostly reversable should it be needed.
