Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 57
Thread: 4 bolt mains
  1. #31
    not to get too far off topic but i noticed the other day that it dosen't look like you can drill a 3500 block on the opposite side for a RWD starter.. do you still have a lx9 block sitting around to verify?
    I could be wrong though...
    I looked into it I was wanting to put a complete stock 3.5 in my 92 5-speed camaro at first. My 92 has a place in the bellhousing for a starter on either side where I ran into problems is I have headers and would had to used a 2000 up small starter and maybe shimed the headers out a 1/4 inch or so which wasn't no big deal,but the fwd starter wouldn't work with my flywheel due to the size maybe could have used a fwd flywheel but didn't know if they would have worked so I just decided to go with the 3.4 hybred instead. Its not together yet though.
  3. #32
    AHAHAHAH you guys think to much lol i have run the intake flipped around facing foreward, stock head gaskets etc, the ONLY problem i have had with my engine is taking out the bottoms of the 2 center bearings when it ran at 7800 rpm for a full 1/4 mile at 15psi, which is no supprise making 500+lbft on a basically stock bottom end at 7800rpm. kinda cool the peel out the length of the track tho
  4. #33
    Ill get you Rwd guys fixed up i think with the 4 bolt caps, full set of studs, balancing and careful machining we can make a reliable 5-600hp with a good twin turbo setup
  5. #34
    Jan 2007
    Ft Lauderdale, FL
    4,270
    Quote Originally Posted by chevette_boy View Post
    Why yes we do, lol.
    I cheked out some RWD manifolds today, the actaully run the coolant the same way as if the FWD manifold is on with the neck to the front.
    We're al good
  6. #35
    N/A all the way Wiz85's Avatar
    Feb 2008
    Cookeville, TN
    48
    Well chevette_boy, did you know that not only are the main caps cross-bolted to the stiff oil pan on the FWD blocks, but also that the windage tray is a heavy ~1/8" stamped steel piece that is bolted to the main caps? Kinda like a stud girdle. For my project since the mains are braced to the oil pan, I'm going to make a 3/16" bead rolled windage tray to add even more strength as well as ARP studs instead of bolts. I thought about 4 bolt mains but I figure this is better for my application and I'm not seeing 500 hp.
    Eric
  7. #36
    Quote Originally Posted by Wiz85 View Post
    running the fwd oil pan would be a huge PITA as well as the accessories and the rwd block is fine i made my 400hp on a basically stock rwd bottom end rebuilt of course
  8. #37
    Surrey, BC, Canada
    5,520
    Not confused. Whats going to get coolant to the back of the heads with the manifolds in the pics? The 3x00 intake has the 2 water ports furthest from the t-stat blocked off. The entire back of the engine is going to get less flow.
    This means the coolant is going to stay in the front of the block in a RWD configuration, correct? It's not going to circulate properly.
    Like I said the coolant holes in the gasket are so important because they direct water flow up to the head.
    Trust me water does not go in one side of the block through one head across the intake to the other head and then out the block on the other side. Our cooling system is exactly like a SBC or BBC. FWD applications would just be slightly different.
    Jan 2007
    Ft Lauderdale, FL
    4,270
    Quote Originally Posted by betterthanyou View Post
    Couple of Corona's that night, lol.
    The gaskets have the same holes in them, and can go on either side of the block. I looked today and saw the RWD has the same routing that the FWD manifold does turned around. My thought is how the FWD configuration would seem to cool #5 and #6 heads and block better than RWD. The coolant is entering/exiting the block at oppposit corners, instead of the same end exit/enter.
  10. #39
    Ortie666's Avatar
    Jul 2005
    Regina Sk, CANADA
    340
    Tell me about it, I was on the street under full throttle in I think 3rd, and went threw a slightly wet spot, and b4 I could lift the bottomend was already making noise from a 8 grand flash, I destroyed all of the bearings and crank, its has an aftermarket electronic ignition, and ive often thought about buying the revlimiter box for it.. what can I say tho, Shit happens when you party naked
    Six-t-Six Motorsports
    2.8L Chevette Roadcar
    3.2L Acadian Racecar
  11. #40
    Surrey, BC, Canada
    5,520
    I think CNCGuy even had a coolant routing diagram. But that may have only been for the external lines.
    The FWD head gaskets may have the same water holes front and rear. But remember the thermostat housing and pump are at different ends. But I am certain the RWD gaskets have large holes only at the rear 2 cylinders. I have not looked at one in like 6 years. But I did just look at an LS1 gasket and they have they have small steam holes at each cylinder water jacket and then the large coolant flow holes only at the rear which allows water from the block to enter the heads.
