The first step will be to check for 5 volts at terminal "C". I didn't think about that since I was closing up shop. Once that's established the remaining two terminals will more than likely be in the correct location and the MAP signal is just steady at max Kpa waiting for crank mode. That makes sense to me considering if there were no MAP sensor plugged up at power on it shouldn't show a WOT reading but instead 0 I would think. When I checked for diagnostic codes there were none and if the MAP sensor was disconnected I believe it would set a code before the engine was started.
